Hi all,
I had some problems due accentaly including debian ppas in /etc/apt/sources.list and then, update system. So my bluetooth started faling. Then I removed some things hoping to fix it when re-installing it. One of the packages I removed is pi-bluetooth ... and when I try to re-install it I got the following error :
pi@raspberrypi02:~/ $ sudo apt-get install pi-bluetooth
Reading package lists... Done
Building dependency tree
Package pi-bluetooth is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'pi-bluetooth' has no installation candidate
Now my /etc/apt/sources.list looks like the following and I already updated the system :
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
Does someone has any clue on what is going on and how to fix it ?
Should I use a different ppa to get it ?
