From Pi to laptop... I'm at laptopbensimmo wrote:Which one are you at Pi or laptop?
Will any of these work for you?
https://www.raspberrypi.org/documentati ... te-access/
If it's for infrequent transfers, use WinSCP. I'm assuming your laptop is running some version of windows; but you didn't state what it's running (that's why it's importat to post all relevant details) so that might not be appropriate.solo2500 wrote:From Pi to laptop... I'm at laptopbensimmo wrote:Which one are you at Pi or laptop?
Sorry for the incomplete information. I'm using a Rp3b with latest image of Raspbian. For the time being the file transfers will be infrequent but may someday be daily. My laptop is a new (relatively) windows machine running 8.1asandford wrote:If it's for infrequent transfers, use WinSCP. I'm assuming your laptop is running some version of windows; but you didn't state what it's running (that's why it's importat to post all relevant details) so that might not be appropriate.solo2500 wrote:From Pi to laptop... I'm at laptopbensimmo wrote:Which one are you at Pi or laptop?
If you've got SSH access to the Pi then winscp will work, scp and sftp use the same connection setup as ssh so use the same details as you use for SSHsolo2500 wrote: It looks like SCP runs on the local network (where I use simba and the built in windows file explorer which works fine) but I want access from outside my local network. I have looked into port forwarding but my router/isp makes things wildly complicated (if not impossible!)
