PI_newbee
Sending CRTL+C to close shell script
Thu Aug 18, 2016 9:26 am
Hi.
How can i send CRTL+C command to terminate one external script ?
This is what am doing:
- waiting for button press
- if detected, run external shell script
- wait 20 seconds
- send termination signal and close shell script
Whole code is written in python and shell script is called as subprocess ( looking for better solution ).
Any idea how to send this crtl+c command ?
PIN
Paeryn
Re: Sending CRTL+C to close shell script
Thu Aug 18, 2016 1:05 pm
CTRL-C usually sends the SIGINT signal to a process so you just need to do that.
Since you say your program is Python this is how to do it from Python :-
import subprocess, signal, time
print("Starting...")
proc = subprocess.Popen("./wait") ## Run program
print("Waiting...")
time.sleep(2) ## Wait a bit
print("Sending CTRL-C...")
proc.send_signal(signal.SIGINT) ## Send interrupt signal
## You can also use one of these two
#proc.terminate() ## send terminate signal
#proc.kill() ## send kill signal (forcibly kill the process, it cannot be trapped so the process can't exit gracefully, use with caution)
She who travels light — forgot something.
PI_newbee
Fri Aug 19, 2016 10:24 am
This is some test program that should start the script on button press and close it after 10 seconds:
import RPi.GPIO as GPIO
import time
import os
import signal
import subprocess
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_UP)
while True:
    input_state = GPIO.input(18)
    if input_state == False:
        print('Start AV streaming')
        os.system("/home/pi/test/script.sh")
        time.sleep(0.2)
def countdown(count):
    while (count >= 0):
        print ('The count is: ', count)
        count -= 1
        time.sleep(1)
countdown(10)
print ("Insert CTRL+C")
print ("Program terminated")
Is this what you are suggesting ?
PIN
Paeryn
Fri Aug 19, 2016 10:45 am
No, use proc = subprocess.Popen() to start the script. os.system() doesn't give you easy access to the process id needed to send it the signal whereas Popen() does. The return value from Popen() is needed so you can call the send_signal() function of it.
If you need to pass arguments to the script then rather than passing a string pass a list of strings otherwise it won't work.
proc = subprocess.Popen(['/home/pi/test/script.sh', 'arg1', 'arg2'])
