pepijntje02
[Solved] Flirc in python
Tue Aug 16, 2016 10:23 am
at the moment I try to connect a FLIRC USB with my raspberry pi. I am not using any media player like XBMC. I want to use the input of the remote to start some parts of a program written in python.
I created a small script using pygame to catch all keyboard input. This works fine for my keyboard, but not when I try to catch the signals from the FLIRC USB. I thought that the USB will give keyboard commands.
I have installed and imported LIRC for python. I have configured the FLIRC USB on my laptop using the flirc software. I am not able to see any input from the USB, so this is not working.
When I search on the internet all information about the FLIRC USB is about the configuration of the USB with XBMC of some other media center.
I hope someone know how to deal with this stuff.
Kind regards,
pepijntje02
hansotten
Re: Flirc in python
Tue Aug 16, 2016 2:10 pm
If I understand the FLIRC specs it behaves as a HID device after programming it.
This means you assign keycodes to IR remote buttons.
Have you tried something simple: program a key IR remote key for example as 'A', plug in the FLIRC in the USB port and see if the A character appears on the commandline?
(full keybaord mapping http://www.howtogeek.com/217587/how-to- ... ia-center/ )
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
DieOma
Re: Flirc in python
Tue Aug 16, 2016 2:42 pm
I recently worked on Flirc and nothing happened until I added Flirc on the device tree
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Uncomment this to override the defaults for the lirc-rpi module
#dtparam=gpio_out_pin=16
#dtparam=gpio_in_pin=17
#dtparam=gpio_in_pull=down
did you do that?
hansotten
Re: Flirc in python
Tue Aug 16, 2016 7:19 pm
Flirc usb is a diffeent device, to be inserted in the usb port, as HID device, keyboard. So lirc is not applicable.
pepijntje02
Re: Flirc in python
Wed Aug 17, 2016 7:57 am
thanks for your response. I tried to configure the FLIRC on my laptop with the FLIRC software. I tried to configure the buttons and I tried to configre some buttons as key-board keys. This did not work.
I did not install something for FLIRC or something else on the raspberry pi. I think that there is something missing. The part about the device tree I do not understand, sorry.
But I have installed lirc (not configured), but as you say that will not help to get the FLIRC keys in my python script?
I tried to install kodi to see if the remote is working there, but I am not able to run kodi from the RPI over ssh/vnc. I only have a laptop so there is no possibility to connect a screen (I think that that is the problem with kodi from raspbian).
I have tried the same program on my laptop with the FLIRC USB and then it works fine. So I think the raspberry pi do not recognize the USB, but I do not know what I have to install or configure on the PI itself to recognize the USB as input device?
DieOma
Re: Flirc in python
Wed Aug 17, 2016 9:23 am
http://python-evdev.readthedocs.io/en/l ... orial.html
Hi, this is the tut for evdev. Seems to be a good Library
hansotten
Re: Flirc in python
Wed Aug 17, 2016 10:11 am
pepijntje02 wrote:Hello,
I just performed a simple experiment with my FLIRC:
1. On the PC with the FLIRC program. Full keyboard config, I recorded a key on my IR remote and assigned it to keyboard 'a'
2. Installed the FLIRC on the Pi (a recent Jessie) and checked if the FLIRC was detected:
$ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 20a0:0001 Clay Logic
The last one is the FLIRC device
$ usb-devices
T: Bus=01 Lev=02 Prnt=02 Port=03 Cnt=02 Dev#= 4 Spd=1.5 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=20a0 ProdID=0001 Rev=01.00
S: Manufacturer=flirc.tv
S: Product=flirc
C: #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=01 Driver=usbhid
I: If#= 1 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
So FLIRC is detected as USB HID device. Pressing the IR key delivers a 'a' on the screen. FLIRC works fine on the Pi!
Note that if you work via remote access to your Pi it will not see FLIRC (or any local keyboard/mouse!) as input device, only your remote keyboard.
Only on the console it will work as keyboard device.
FLIRC is this device:
/dev/input/by-id/usb-flirc.tv_flirc-event-kbd
pepijntje02
Re: Flirc in python
Wed Aug 17, 2016 11:14 am
I can see my FLIRC device with both commands, lsusb and usb-devices.
What I want to try is to create a program and that I can put the raspberry in a place and I can send commands to it using the remote. For example, when the raspberry is connected to a relay I want to use the remote to turn on or of the relay on a specific GPIO pin. This is thus the same as a web-app, but then with the remote.
I understand what you mean with that the remote is not recognized because I use vnc, this is the same for my mouse (I just tested it). Do you know a way to use the remote for my programs and that it is recognized as an input device?
thanks for your help so far, now I know that it is recognized but that the remote asses is the problem! :(
hansotten
Re: Flirc in python
Wed Aug 17, 2016 11:49 am
pepijntje02
Re: Flirc in python
Wed Aug 17, 2016 12:21 pm
Thank you very much. This works fine now!
I have to make it better and I have to teach myself how it actually works, but I get signals so now it time to learn and play.
I think that there is a lot of noise on the signal, since I get the same code for different buttons, but I think that that is noise from the remote or the control, but I have to find out how to deal with it.
As I said, it works for now, thank you very much now I can finally use the remote on my pi! :D
thank you!
Return to “Advanced users”
