hack3d
Cross compile Qt5 application
Mon Aug 15, 2016 12:52 pm
Hi guys,
I have a qt5 application which can be run on x86 and ARM. I'll have to compile both binaries on different machines.
Is there a way to cross compile a qt5 application without useing the pi for it?
topguy
Re: Cross compile Qt5 application
Tue Aug 23, 2016 10:17 am
hack3d wrote:Is there a way to cross compile a qt5 application without useing the pi for it?
Yes.
Is it easy to set up ?
No.
Is it worthwhile ?
Depends. How often do you need to recompile the program ? How long does it take to compile on the Pi ?
hack3d
Tue Aug 23, 2016 1:53 pm
Thanks for your reply.
I want to compile it after every commit. So it could be often.
Do you have some sources for setting up such an system?
Return to “Graphics programming”
