a.stewart.au
Camera module raspistill not working!
Mon Aug 15, 2016 5:45 am
I am using a RPi with a camera module. I've installed a MATLAB support package onto it which allows the MATLAB on my PC to communicate with the RPi and take photos over the network.
I now want to be able to use commands on the RPi like 'raspistill' to take pictures, but I can't do this while it's in use by the MATLAB server! I am getting this error:
pi@raspberrypi-mvHdY05c5o:~ $ sudo raspistill -o cam.jpg
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
How can I free the camera from the MATLAB server so that I can use raspistill?
Re: Camera module raspistill not working!
Tue Aug 16, 2016 2:21 pm
What do you get from a vcgencmd get_camera command?
boboyee2001
Mon Aug 29, 2016 3:22 am
hello i am having the exact same problem
i used the vcgencmd get_camera and got
supported=1 detected=1
Dougie Lawson do you have any insight on this problem
mbelge
Fri Sep 02, 2016 2:54 pm
MATLAB server grabs the camera only when user creates a "cameraboard" object. So if you have a cameraboard object just clear it and MATLAB server will release the camera.
Example:
>> r = raspi;
>> cam = cameraboard(r);
>> img = snapshot(cam);
>> clear('cam')
>> system(r,'raspistill -o test.jpg')
>> getFile(r,'test.jpg')
>> image(imread('test.jpg'))
