tmanieropiron
Re: LVDS add-on for Raspberry models with 40pin GPIO
Thu Nov 08, 2018 11:30 am
write to t.maniero at piron dot it
Thank you!
Thomas
dennisc
Mon Feb 25, 2019 10:18 am
Please let me know how to get my email address across to you! Would like to buy one.
aBUGSworstnightmare
Fri Mar 01, 2019 7:14 pm
dennisc wrote: Please let me know how to get my email address across to you! Would like to buy one.
do it in the same way as Thomas did in the post before yours!
Let me know which display you want to connect (either post.the data sheet or a picture of the LVDS mapping) as I need to check if the remaining boards can be used.
dennisc
Mon Mar 04, 2019 7:00 pm
here we go!
xxx _at_ me _dot_ com
dennisc
Tue Mar 05, 2019 8:03 am
here is the datasheet!
aBUGSworstnightmare
Tue Mar 05, 2019 9:02 am
dennisc wrote: here is the datasheet!
Pinout is not what I'm interrested in!
I need to know the LVDS data mapping. So, please check your display spec for some informaton like the one shown below.
Y0= ...R1,R0 LVDs mapping
Your display need to have this mapping as there are no PCBs left which support Y0=..R3,R2 (look at the first post in this treath for seeing the difference).
dennisc
Tue Mar 05, 2019 10:01 am
I think it is the right version!
aBUGSworstnightmare
Tue Mar 05, 2019 10:04 am
yes, mapping is correct. I will let you know the details by e-mail.
have you received my e-mail btw?
aBUGSworstnightmare
dennisc
Tue Mar 05, 2019 10:08 am
made a mistake in writing it...
xxxx _at_ me _dot_ com
sorry!
aBUGSworstnightmare
Tue Mar 05, 2019 10:20 am
Just send an e-mail to <somebodys mail address > with details.
Let me know if you've received it.
aBUGSworstnightmare
Fri Mar 08, 2019 8:54 am
Sharp LQ121S1LG81 timing
#h_active_pixels = 800
#h_sync_polarity = 1
#h_front_porch = 168
#h_sync_pulse = 2
#h_back_porch = 86
#v_active_lines = 600
#v_sync_polarity = 1
#v_front_porch = 43
#v_sync_pulse = 2
#v_back_porch = 21
#v_sync_offset_a = 0
#v_sync_offset_b = 0
#pixel_rep = 0
#frame_rate = 60
#interlaces = 0
#pixel_freq = 40000000
#aspect_ratio = 1
Sharp LQ121S1LG81 connected to LVDS4PI
TomekRST
Wed Mar 13, 2019 10:01 pm
Hi!
Interested in your product. I can’t PM you. Could you send me your email over here: tomtom.mk2 at gmail
Thanks in advance.
Tomek
aBUGSworstnightmare
Thu Mar 14, 2019 5:56 am
Hi!
Thanks in advance.
Tomek
PM function has been disabled on the RPI forum quite a while ago.
Well, I would not call the board 'a product'; it's more a proof-of-concept. Will send e-mail with dot-com domain; let me know in case you did not receive it.
kelroy
Wed May 22, 2019 8:32 pm
Hi!
Thanks in advance.
Tomek
Hi aBUGSworstnightmare, i was reading the whole post and others about dpi to lvds and this inspired me to design one, really thanks to your work man. But i am having a small problem. I really dont know how to obtain the correct dpi_timings and dpi_output_format. Could you help me please?
Or if it's some tutorial/detailed guide to obtain this.
Some photos of my actually job (it's a prototype so i make the things big xD):
Board:
Datasheet:
RGB format, actually i se the jumper to 8.
aBUGSworstnightmare
Thu May 23, 2019 6:04 am
Details on DPI are here https://www.raspberrypi.org/documentati ... /README.md
Your display spec should have all the details to figure out dpi_oitput format. You've posted some of the timing details already, polarity infos should be available from some chart in your dieplay spec.
kelroy
Thu May 23, 2019 9:34 am
Yes, at least i understand the dpi_output_format.
But on the timmings... i just inderstand a few things like the h and v lanes, frame rate.... but the others, i could not figure how to obtain this in base of the datasheet.
Finally i have it working, damm chinesse datasheets... they are really bad.
aBUGSworstnightmare
Thu May 23, 2019 1:49 pm
There should be a chart that explains values from table 3.3.4
There you can see how polarities are etc. And how to interpret the rest
kelroy
Fri May 24, 2019 9:36 am
Yes, finally i made it works. At least was hard but i found this post that explain a bit things and with that and other reads i found a solution.
That its the post i saw: https://timetoexplore.net/blog/video-ti ... 720p-1080p
Raquena
Wed Aug 14, 2019 12:19 pm
Hello Everybody, and ,pre specifically @MichaR and @@aBUGSworstnightmare,
I'm also interested in building a DPI to LVDS interface for a screen with DUAL LVDS (so I'll be converting 24bit DPI to to SINGLE to DUAL LVDS).
Right now I'm testing the first boards I designed for the specific scree, and as it was expected, it didn't work at the first chance :(
So I'd like to ask you guys, if you could help me a little with the troubleshooting!
Right now, the best I got was:
- green horizontal ribbons.
- red vertical lines.
- not much more... and not for more than 30 seconds.
My current steup is based in MichaR's schematic.
Any ideas of what (or how many things) could generate such state?
Raquena
Wed Aug 14, 2019 4:18 pm
Thu Nov 08, 2018 8:23 am
tmanieropiron wrote: Hi aBUGSworstnightmare,
may I ask if you have two spare lvds boards to sell? I would really like to buy two to play with our lvds displays that currently we are using on another board that have native lvds support.
Thank you,
Thomas
let me know your e-mail address and I can send you the details.
Hello @aBUGSworstnightmare,
I'm trying to send you some private messages regarding to the LVDS interface, but it seems I'm not allowed to do so.
Would be great if you could share with me some of your knowledge regarding to interfacing the raspi with DPI and LVDS.
Thaaaanks!
aBUGSworstnightmare
Thu Aug 15, 2019 6:51 am
I know MichaR's schematic and the LVDS transmittter he's using. Make sure it's control signals are correct (data mapping i.e,) for your display. As I'm using a different transmitter on my expansion board for the LVDS4CM3L board (https://www.raspberrypi.org/forums/view ... 0#p1385429) I can't help with debugging your HW.
What about your dpi_timings etc? Is this correct?
https://www.raspberrypi.org/documentati ... /README.md has all the details. You will have to consult your display data sheet for the values.
Raquena
Thu Aug 15, 2019 1:51 pm
The screen I'm using is WF123BSWAYLNN0
The datasheet that could be found around doesn't contain the timing data, hopefully yesterday I got another datasheet with some more
pages about it :)
I'm not very sure if I'm interpreting the timings completely right though.
Here we go with the timings:
About the configuration, I'm using falling edge clock (that's what I understand from the datasheet).
As far as I('m able to), know the signals are ok:
I'm using a 100MHz Oscilloscope to measure the signals, which seem to be too fast, but at least I know both in the side of the DPI
and in the side of thr LVDS I have signal.
Shouldn't I get at least some random stuff in the screen even if the data format is wrong?
Could it be that I have problems with the power cycle, and that's why I get the scree n displaying stuff only for some seconds?
(indeed, to make it even more strange, the screen shows sth. only after a long time being unpowered, when I power it for the first time).
My mail address is raquena at live dot com, just in case you want to share also some more information per mail
Thank you very much for your help!
aBUGSworstnightmare
Thu Aug 15, 2019 10:28 pm
What you've posted here is no timing data! It's the LVDS mapping - which is VESA btw.
You will need to have timing data (see an example here https://www.raspberrypi.org/forums/memb ... e&u=152468) of your screen; without you're screwed up
Raquena
Fri Aug 16, 2019 9:03 am
Hello again,
The link sends me to your profile, so still not sure if this is what you mean, but I think it looks like:
I'm also trying to attach the complete datasheet, but not allowed, because of size reasons.
Anyway, even if the timings are wrong, I should get some random stuff on the screen, right?
