I'd really appreciate some help on this one.
So I have a pushbutton hooked up to the GPIOs of my Pi2 Model B, in order to record Mic-Input from an USB Audiostick (https://amzn.com/B0027EMHM6) for as long as the button is pushed.
Works fine on the first run but Python alsways kicks me out as soon as I try it a second time (the script is a loop. button pushed > start recording > button released > finish recording & create wav file > button pushed > start recording > and so on).
so here's my script:
#!/usr/bin/python
import RPi.GPIO as GPIO
import pyaudio
import wave
import time
FORMAT = pyaudio.paInt16
CHANNELS = 1
RATE = 44100
CHUNK = 512
RECORD_SECONDS = 5
WAVE_OUTPUT_FILENAME = "rec41000.wav"
p = pyaudio.PyAudio()
#audio_info = p.get_device_info_by_index(0)
#print (audio_info)
#GPIO pin setup for button
ledPin = 18
buttonPin = 23
#set up GPIO using BCM numbering
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
#enable LED and button (button with pull-up)
GPIO.setup(ledPin, GPIO.OUT)
GPIO.setup(buttonPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
#set LED to OFF
GPIO.output(ledPin, GPIO.LOW)
while(True):
print "waiting for button event"
#wait for button to be pressed
time.sleep(0.2)
GPIO.wait_for_edge(buttonPin, GPIO.FALLING)
while True:
try:
frames = []
stream = p.open(format = FORMAT,
channels = CHANNELS,
rate = RATE,
input = True,
frames_per_buffer = CHUNK)
print "* recording"
#turn on LED ring when recording starts
GPIO.output(ledPin, GPIO.HIGH)
#record as long as button held down
while GPIO.input(buttonPin) == 0:
data = stream.read(CHUNK)
frames.append(data)
break
except IOError:
printer.println(textWrapped('- Aufnahmefehler. Starte neu, Moment bitte. -', 32))
# button released
print "* done"
stream.stop_stream()
stream.close()
p.terminate()
#make wave file from recorded data stream
wf = wave.open(WAVE_OUTPUT_FILENAME, 'wb')
wf.setnchannels(CHANNELS)
wf.setsampwidth(p.get_sample_size(FORMAT))
wf.setframerate(RATE)
wf.writeframes(b''.join(frames))
wf.close()
pi@bcfpi:~/bcfnikki $ python record5sec.py
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
* recording
* done
-- the main loop restarts here --
File "record5sec.py", line 55, in <module>
File "/usr/local/lib/python2.7/dist-packages/pyaudio.py", line 750, in open
stream = Stream(self, *args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/pyaudio.py", line 441, in __init__
self._stream = pa.open(**arguments)
IOError: [Errno -9996] Invalid input device (no default output device)
My Pi is running with Raspbian GNU/Linux 8 (jessie). As I didn't get the latest version of PyAudio with 'sudo pip install pyaudio' right away (quit with error message) I had to do this to get the 0.2.9 Package installed: sudo apt-get install portaudio19-dev python-all-dev python3-all-dev && sudo pip install pyaudio
Any ideas what might be the problem, here? Any help is much appreciated.
