Mn1
Raspberry Pi boot
Fri Aug 12, 2016 8:40 am
When I boot raspberry pi I got following warning:
No individual configuration file found for this terminal. Parameters from all.wtc configuration file and default values of parameters will be used. On computer 192.168.2.50 run Start>WTware>Configurator, select terminal MAC B8:27:EB:98:E6:89 and create configuration file Then this message will no longer appear.
When I wrote on terminal 192.168.1.1
Then on terminal window I got:
Server 192.168.1.1 port 3389: Connection rejected. Make sure that terminal service works on this server. Try to connect using mstsc.exe.
What I have to do login?
Romonga
Re: Raspberry Pi boot
Fri Aug 12, 2016 12:43 pm
Not enough information IMHO to help you.
This does not look like a Raspbian error. This looks like an error that was generated on a windows machine.
You can run, but you will only die tired.
W. H. Heydt
Sat Aug 13, 2016 3:52 am
Minor note...generally speaking "192.168.1.1" is the router gateway address. It is very unlikely that a Pi would have that IP address.
Mn1
Mon Aug 15, 2016 6:38 am
Probably, I have to write on this forum: http://forum.wtware.com/viewforum.php?f=23
Thanks.
