My keyboard flips out at times when using OpenELEC; As if it had a key pressed down. Afaik this should be a power problem:
In my hub I'm using
this keyboard https://www.modmypi.com/shop/raspberry- ... -UK-layout
this mouse https://www.modmypi.com/shop/raspberry- ... -wired-USB
1x 16gb Verbatim USB 2.0 flash drive
and 1x 8gb USB 2.0 Flash Drive (brand unknown - cheap)
This usb-hub is plugged in one of the usb-ports of the PI and one more 16GB Verbatim Flashdrive is in the other.
Now for the actual question:
How much power do these devices consume? What should I plug in the RPi's secondary Usb-port? Should it be the keyboard or the usb-flashdrive? Shouldnt 1A be enough power for these 4 devices? And how am I supposed to plug a wifi-dongle in that usb-hub if it flips out even with this setup?
Can someone put these devices (Wifi-dongle, Keyboard, Optical mouse, 16gb flashdrive, 8gb flashdrive) in an order of supposed power consumption? Wifi dongle probably consumes the most, but how much do the other devices consume usually?
