When I first attached the raspberry pi to my TV I had a problem with a red 'snow' appearing on the TV. I think I just rebooted the PI and it went away. BUT then later the red snow appeared once or twice with the pi not connected. Got rid of it by going into menu and out again (on the TV). Then we finally powered off the TV fully for a while. THEN finally the TV is black and won't work.
So, this may have been a coincidence but it does seem unlikely. Most likely explanation is there was too much voltage on the HDMI, it caused a fault in the TV which went on to cause other faults.
Has anyone else experienced anything similar?
I'm planning to bin that pi and buy a new one and only use it with a less expensive tv!!
