solo2500
cron job?
Sat Aug 06, 2016 5:05 pm
Can anyone tell me if the formatting of this crontab entry is correct?
0 6 * * * /etc/init.d/ service motion start
1 13 * * * /etc/init.d/ service motion stop
I see that it runs. This is what I get from the log file:
Aug 6 13:01:01 VIDraspberrypi CRON[1083]: (root) CMD (/etc/init.d/ service motion stop)
But Motion does not stop? It's got to be something simple but I'm to dense to figure it out... Any ideas.
THANKS for any help!
I'm a total novice, non-programer (...basically a hack.)
stderr
Re: cron job?
Sat Aug 06, 2016 5:18 pm
solo2500 wrote:But Motion does not stop?
Does it stop when you use that command at the command line? Does it require root privileges? Are you using a normal user crontab or root's?
solo2500
Re: cron job?
Sat Aug 06, 2016 5:33 pm
Yes... When I use sudo service motion stop at the command prompt it stops. The cron job is in the root.. ie sudo cron -e
rpdom
Re: cron job?
Sat Aug 06, 2016 5:37 pm
But your crontab isn't running "service motion stop". It's running "/etc/init.d/ service motion stop", which is not a valid command.
Try
0 6 * * * /usr/sbin/service motion start
1 13 * * * /usr/sbin/service motion stop
solo2500
Re: cron job?
Sat Aug 06, 2016 5:48 pm
THANK YOU... THANK YOU.... THANK YOU!!!
I love you... man!
I just started learning Pi and linux! The depth of my ignorance seems infinite! Thanks again!
Return to “Beginners”
