My Pi3 is booted for the first time with a brand new SD card loaded with NOOBS. It has booted successfully, as evidenced by the ethernet port LEDs flashing with a connection. The HDMI out is connected to an active (and working) HDMI-VGA adapter, which is connected to a VGA monitor. However, the monitor doesn't recognize this fact, and it says "cable not connected".
Okay, so the monitor doesn't recognize the Pi3. Fine. BUT, I need to see what the Pi3 is doing so that I can shut it down without screwing up the SD card. So, what other ways can I display the Pi3's output WITHOUT shutting it off?
