prupert
Expand My Imaged Noobs Install To Use All SD Card Space
Tue Aug 02, 2016 8:58 pm
Hi
I have a Raspi 2b+ (one of many Raspis I own). I installed Rasbian on it via Noobs around 1 year ago and made many modifications to the install (mainly hacking my own PIR powered ambilight / picture slide show). Annoyingly I did all this on an 8GB card that has now run out of space due to the photos I store on it (for the picture slide show)
I have a larger card and I assumed I could image the 8GB card (using win32diskimager) and write that to a larger 64GB card and then simply run raspi-config and select the Expand File system option). BUT, when I do this, I get a message saying it looks like I used Noobs and the filesystem is already expanded, which it isn't as df -h still lists the 64GB card as 8GB :(
I have found this info: http://elinux.org/RPi_Resize_Flash_Partitions but these instructions (the manual instructions) seem to be written for non Noobs installs and I was concerned if I went ahead, I might bork my install entirely since it is Noobs based.
Any one any ideas how to get round this?
Re: Expand My Imaged Noobs Install To Use All SD Card Space
Tue Aug 02, 2016 9:13 pm
The latest release of Raspbian Jessie has SD Card Copier: https://www.raspberrypi.org/blog/anothe ... e-raspbian ??????
The program does not restrict you to only copying to a card the same size as the source; you can copy to a larger card if you are running out of space on your existing one, or even to a smaller card (as long as it has enough space to store all your files – the program will warn you if there isn’t enough space). It has been designed to work with Raspbian and NOOBS images; it may work with other OSes or custom card formats, but this can’t be guaranteed.
Thinking outside the box is better than burying your head in the sand...
prupert
Tue Aug 02, 2016 9:37 pm
Aha, if I simply apt-get updated (or apt-get dist-upgrade) would I get access to this tool?
Hope so, since that would be awesome.
Thanks for this info.
Return to “Advanced users”
