Does anyone have a good method of printing a fairly large config file?
Thanks!
Sorry for the poorly written question. I want to print it to paper. Whatever format the nano editor uses. (I'm guessing that is probably not what you are asking?)SonOfAMotherlessGoat wrote:Printing in what way? Printing to file, to screen, to paper? And is the config file formatted in any kind of structured way? (JSON, XML, YAML, etc.)
I do not believe Nano has a print function, maybe open the file in another plain text editor which has a Print Function ?solo2500 wrote:Sorry for the poorly written question. I want to print it to paper. Whatever format the nano editor uses. (I'm guessing that is probably not what you are asking?)SonOfAMotherlessGoat wrote:Printing in what way? Printing to file, to screen, to paper? And is the config file formatted in any kind of structured way? (JSON, XML, YAML, etc.)
Thanks!
Is there an editor with a print function built into Raspbian?fruitoftheloom wrote:I do not believe Nano has a print function, maybe open the file in another plain text editor which has a Print Function ?solo2500 wrote:Sorry for the poorly written question. I want to print it to paper. Whatever format the nano editor uses. (I'm guessing that is probably not what you are asking?)SonOfAMotherlessGoat wrote:Printing in what way? Printing to file, to screen, to paper? And is the config file formatted in any kind of structured way? (JSON, XML, YAML, etc.)
Thanks!
LeafPadsolo2500 wrote:Is there an editor with a print function built into Raspbian?
Thanks again!
Other than the unknown connotations of 'good' and 'fairly large', I wonder what lies behind the question? Just for starters: does the system from which you wish to print have a connection to a working printer?solo2500 wrote:Does anyone have a good method of printing a fairly large config file?
THANK YOU!fruitoftheloom wrote:LeafPadsolo2500 wrote:Is there an editor with a print function built into Raspbian?
Thanks again!
https://www.raspberrypi.org/documentati ... editors.md
