SilverCrafter7
Minecraft BlockEvents
Mon Aug 01, 2016 2:14 am
Hi I'm trying to get this to work, but I'm not sure how to use the block event type correctly. Thoughts?
from mcpi.minecraft import Minecraft
from time import sleep
mc = Minecraft.create()
myCoords = mc.player.getPos()
blockEvent = mc.events.pollBlockHits()
DIRT = 3
blockEventType = blockEvent.HIT
if blockEventType == True:
    mc.postToChat("Hey! Don't Hit me!")
scotty101
Re: Minecraft BlockEvents
Mon Aug 01, 2016 9:19 am
You need to put the check for an event inside a loop otherwise it only happens once.
Also you set blockEventType to be blockEvent.HIT which means that your if statement will never be true.
If you describe what you want, I can help you with an example.
I'm guessing that you want to have the message "Hey! Don't Hit me!" appear when you hit a dirt block. Is that correct?
scotty101
Mon Aug 01, 2016 9:28 am
Here is a simple example of reading block hits
import mcpi.minecraft as minecraft
import time
mc.minecraft.Minecraft.create()
while True:
    hits = mc.events.pollBlockHits()
    for hit in hits:
        print("You hit block ({},{},{})".format(hit.pos.x,hit.pos.y,hit.pos.z))
    time.sleep(0.1)
SilverCrafter7
Mon Aug 01, 2016 2:20 pm
thx for the help I changed print to mc.postToChat
Return to “Python”
