Lintest Systems is launching a line of video capture boards for the Raspberry Pi, starting with the PiCapture SD1.
PiCapture SD1 captures standard-definition interlaced video in the CVBS standard (NTSC/PAL) from Composite, S-Video, and YPbPr Component sources as 640×480 video.
By using the Raspberry Pi CSI-2 camera interface and providing complete camera emulation, all of the video encoding and management capabilities of the Raspberry Pi are usable with any compatible video source. In addition, applications that require large amounts of Raspberry Pi resources (e.g. real-time image processing) are now enabled since USB capture devices are not required.
You can see examples of captured video at: http://lintestsystems.com/sd1-examples
Detailed information about the PiCapture SD1 can be found on our web site: http://lintestsystems.com
