roblan
over-current change log spam
Fri Jul 29, 2016 4:53 pm
Hi
I've a problem with spam in syslog.
Every fraction of second I get
usb 1-1-port2: over-current change
Is there any way to ignore this? Maybe disable over-current warning, or logging msg that are not warning at least?
I've been googling around, but haven't found anything.
DirkS
Re: over-current change log spam
Fri Jul 29, 2016 8:05 pm
I would start by trying to solve the power problem instead of ignoring it...
davidcoton
Fri Jul 29, 2016 9:19 pm
Which model of Pi?
What is connected to the USB ports?
What PSU?
Likely not relevant, but what OS?
Signature retired
roblan
Sun Jul 31, 2016 8:42 am
Model: Pi 2 B+
On this port is a USB HDD (WD Red in powered Natec RHINO case)
There is also RPi Wi-Fi dongle on other port.
OS is Raspbian
Pi (and Pi Display) are connected to http://www.ikea.com/gb/en/catalog/products/70280993/ (display and Pi are powered separately, but connected through pins)
When I use this disk "more" (open some video file through samba, etc.) those messages usually stops
davidcoton
Sun Jul 31, 2016 11:41 am
Have you set the higher current limit for the USB ports? To do so,
add "max_usb_current=1" to config.txt
Signature retired
roblan
Mon Aug 01, 2016 4:13 pm
I've already tried this. There was no difference.
davidcoton
Mon Aug 01, 2016 4:32 pm
Disconnect both USB peripherals. Does that stop the message? Reconnect one at a time to determine whether one peripheral is responsible, or whether it is just the total load of all USB peripherals that causes it.
Signature retired
roblan
Mon Aug 01, 2016 5:44 pm
Looks like it's neither nor ;)
When I disconnect Wi-Fi dongle I still get message flood in log.
Disconnecting USB HDD stops it. So it looks like it's HDDs fault.
But when I reconnect HDD (with plugged Wi-Fi dongle) there is no over-current message. At least for now.
I'll check if it comes back (maybe there are somewhere power settings? like hdd sleep?)
over 30 minutes and still no over-current warning...
Hm... Maybe this is similar case to viewtopic.php?p=997498#p997498 ?
I'll try it out later :)
