#!/usr/bin/env python
# This is a program for all ADC Module. It
# convert analog singnal to digital signal.
# This program is most analog signal modules'
# dependency. Use it like this:
# `import ADC0832`
# `sig = ADC0832.getResult(chn)`
# *'chn' should be 0 or 1 represent for ch0 or ch1
# on ADC0832
# ACD1302 Pi
# CS ---------------- Pin 11
# CLK --------------- Pin 12
# DI ---------------- Pin 13
# VCC ----------------- 3.3V
# GND ------------------ GND
import RPi.GPIO as GPIO
import time
ADC_CS = 11
ADC_CLK = 12
ADC_DIO = 13
# using default pins for backwards compatibility
def setup(cs=11,clk=12,dio=13):
global ADC_CS, ADC_CLK, ADC_DIO
ADC_CS=cs
ADC_CLK=clk
ADC_DIO=dio
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD) # Number GPIOs by its physical location
GPIO.setup(ADC_CS, GPIO.OUT) # Set pins' mode is output
GPIO.setup(ADC_CLK, GPIO.OUT) # Set pins' mode is output
def destroy():
GPIO.cleanup()
# using channel = 0 as default for backwards compatibility
def getResult(channel=0): # Get ADC result, input channal
GPIO.setup(ADC_DIO, GPIO.OUT)
GPIO.output(ADC_CS, 0)
GPIO.output(ADC_CLK, 0)
GPIO.output(ADC_DIO, 1); time.sleep(0.000002)
GPIO.output(ADC_CLK, 1); time.sleep(0.000002)
GPIO.output(ADC_DIO, channel); time.sleep(0.000002)
dat1 = 0
for i in range(0, 8):
GPIO.output(ADC_CLK, 0); time.sleep(0.000002)
GPIO.setup(ADC_DIO, GPIO.IN)
dat1 = dat1 << 1 | GPIO.input(ADC_DIO)
dat2 = 0
dat2 = dat2 | GPIO.input(ADC_DIO) << i
GPIO.output(ADC_CS, 1)
if dat1 == dat2:
return dat1
else:
return 0
def getResult1():
return getResult(1)
def loop():
while True:
res0 = getResult(0)
res1 = getResult(1)
print('res0 = %d, res1 = %d') % (res0,res1)
time.sleep(0.4)
if __name__ == '__main__': # Program start from here
setup()
try:
loop()
except:
KeyboardInterrupt
destroy()
Ascottgent
