zfyseu
problems about building a raspbian kernel
Wed Jul 27, 2016 9:04 am
Hello,everyone!
I try to follow the link "https://www.raspberrypi.org/documentati ... uilding.md" to build my own raspbian kernel.
Everything seems go well. However after I run the command "make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- INSTALL_MOD_PATH=mnt/ext4 modules_install"
there are nothing in the directory mnt/ext4.
Is there anyone know how to solve the problem?
Thanks!
zfyseu
Re: problems about building a raspbian kernel
Wed Jul 27, 2016 11:21 am
I have known the reasons.
the "mnt/ext4" should be "/mnt/ext4"
however it can't boot.
Is there anyone know where to find the "bootcode.bin " and "start.elf"?
Thanks!
Thu Jul 28, 2016 6:41 am
Get the config with
sudo modprobe configs
zcat /proc/config.gz
Get the bootcode etc. from https://github.com/Hexxeh/rpi-firmware/ ... master.zip
Get the kernel source with https://github.com/Notro/rpi-source read the Wiki for that at https://github.com/Notro/rpi-source/wiki
zfyseu
Thu Jul 28, 2016 7:18 am
Hello, DougieLawson!
Do you know how to edit the kernel option when cross compile the raspbian kernel?
Thanks.
Thu Jul 28, 2016 7:53 am
make oldconfig # to read an existing config file
make menuconfig # to use the config editor
zfyseu
Thu Jul 28, 2016 8:10 am
Thanks!
I have tried what you said.
however when I run "make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage modules dtbs"
it will returns:
"scripts/kconfig/conf --silentoldconfig Kconfig
Restart config... * *
Configure standard kernel features (expert users) * Configure standard kernel features (expert users) (EXPERT) [Y/?] y Enable 16-bit UID system calls (UID16) Y/n/? "
Do you know how to deal with it?
Thanks!
