Usually the out of the box Rpi3 does not connect to the internet through its
internal Wi-Fi Module as it is un configured and the network/interfaces file is
unedited
This method provides an ease to connect the Rpi-3' internal wifi to connect to an
Access Point in range in Ad-hoc mode ,it has been tested and works well on my Rpi3
also works with Ad-Hoc n/w on a External Wifi Router or Hotspot Access Point Setup
via a mobile phone.
to do this i have used "iwconfig" command on terminal
Step 1:
From root terminal :
when rpi3 internal wifi is up & wifi Router is also up and in range
type "sudo iwlist wlan0 scan "
it will reveal normally:
wlan0 Scan completed :
Cell 01 - Address: xx:xx:xx:xx:xx:xx
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=36/70 Signal level=-74 dBm
Encryption key:off
ESSID:"YOUR WIFI ROUTER ESSID"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 6 Mb/s; 9 Mb/s
11 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Ad-Hoc
Extra:tsf=0000000000000000
Extra: Last beacon: 23050ms ago
IE: Unknown: 000A353830305F5870726573
IE: Unknown: 010882840B0C12161824
IE: Unknown: 030101
IE: Unknown: 06020000
IE: Unknown: 32043048606C
"NOTE DOWN" or Copy the "cell id: XX:XX:XX:XX" this the AP used later
also note or copy ESSID"YOUR WIFI ROUTER ESSID"
Step 2:
Type in command line:
"iwconfig wlan0"
this will reveal the following:
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Cell: Not-Associated Tx-Power=1496 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Here we check the values of: cell (AP),mode ,ESSID ..
To establish connection in Ad-Hoc Mode the the variables (Noted Above) should be configured
Step 3:
Make sure the Wifi Router or Access point or mobile wifi access point (Device broadcasting the web network) is active in range and configured in Ad-Hoc Mode.
type
$iwconfig wlan0 essid xxxxxx //"or your desired ESSID"
$iwconfig wlan0 mode Ad-Hoc //"default"
$iwconfig wlan0 ap XX:XX:XX:XX:XX //" AP mac address of router(taken from earlier)
Do "$iwconfig wlan0" again twice to check the data variable values have changed or not.
normally:
$iwconfig wlan0
wlan0 IEEE 802.11bgn ESSID:"5800_Xpres"
Mode:Ad-Hoc Frequency:2.412 GHz Cell: 5C:57:C8:45:18:68
Tx-Power=1496 dBm
Encryption key:off
Power Management:on
Finally :To Activate wifi connection type : " sudo dhclient wlan0" to connect
and : "dhclient -x" to STOP the dhclient process, and end the wif Ad-Hoc Mode connection.
