hfr1988
Run python script as cgi under apache2 server[my experience]
Sun Jul 24, 2016 4:58 pm
I was trying to set up a server with Pi 3, so I ran into this python CGI + Apache server path. Here is what I did and it works:
1. Install apache2 first, after the installation you should be able to see the default page with 'localhost' in your browser.
sudo apt-get install apache2
2. Enable mods in apache2 for cgi (the codes below showed two ways to do it)
sudo a2enmod cgid
cd /etc/apache2/mods-enabled
sudo ln -s /etc/apache2/mods-available/cgi.load
3. Modify the config file: /etc/apache2/conf-enabled/serve-cgi-bin.conf to enable python code.
<Directory "usr/lib/cgi-bin">
             AddHandler cgi-script .py          # add this line (there is a blank between cgi-script and .py)
</Directory>
4. Notice that the default directory for cgi script is /usr/lib/cgi-bin/, so we will create a test file under this directory.
sudo nano /usr/lib/cgi-bin/pytest.py
#!/usr/bin/python
import cgi
import cgitb
cgitb.enable()
print 'Content-type: text/html\n\n'
print '<h1>Python Script Test</h1>'
5. Make the python file executable
sudo chmod +x /usr/lib/cgi-bin/pytest.py
6. Restart the apache2 service
sudo service apache2 restart
Now you should be able to see your test file output under 'localhost/cgi-bin/pytest.py' in your browser.
Note: I was having trouble restart the apache2 service after enable the cgi mods. So I actually reinstalled the apache2, it works after that. Here is how I reinstalled the apache2:
sudo apt-get --purge remove apache2
sudo apt-get autoremove
Hope this experience can help someone. Please let me know if there are anything need to be modified.
Bruce Crowthorne
Re: Run python script as cgi under apache2 server[my experie
Tue Jan 10, 2017 7:25 pm
Thanks for your write up, it is very clear and has nearly helped!
My test set up is a fresh build on a RPi1 with Jessie and Apache 2.4.10.
I created the pytest.py file as you suggest. It is in cgi-bin and it is executable.
I have tried to follow your notes as closely as I can and think I have completed each step, but I get an "500 Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request."
Any suggestions of what I can check or try
Bruce
Moolectro
Tue Apr 04, 2017 3:40 am
Hi
I'm follow your write up. It succeeded. No problem. But the requested URL was not found. Why?
Halp me please. :oops: :oops: :oops:
peterv6i
Re: Run python script as cgi under apache2 server[my experience]
Wed Sep 20, 2017 7:16 am
I have followed your instructions on raspberrypi zero w and it works well..
ChrisseDD
Sun Nov 05, 2017 3:28 pm
Hi, It do not work for me. :(
I´m not able to restart the apache. The reinstall doesn´t help. Anybody able to help me?
btw: I´m a Pi-Newbe :oops:
Tue Nov 07, 2017 12:45 am
That photo almost tells you what's wrong.
Try systemctl -l status apache2 and your syntax error in line#146 should be more obvious.
This is a doctor free zone.
dcristut
Mon Jan 22, 2018 10:39 am
Thank you for the helpful tutorial.
I am trying something: I want to put the CGI module (pytest.py) in some other directory : /home/pi/usbdrive/www/cgi-bin
Therefore I have changed the configuration file /etc/apache2/conf-enabled/serve-cgi-bin.conf like this: <Directory "/home/pi/usbdrive/www/cgi-bin"> and put the pytest.py file in that directory.
But I have a problem with user rights: "You don't have permission to access /cgi-bin/pytest.py on this server."
Any idea how should I configure that directory or what configuration parameters are needed?
Thank you
luvnits94
Fri Apr 20, 2018 10:11 pm
I have followed your post closely and it was really helpful .
Now i am able to execute a perl script (eg test.pl )
But when i try to execute a python script (e.g pytest.py ), I get the following error in apache error log
AH01215: (8)Exec format error: exec of '/usr/lib/cgi-bin/pytest.py' failed
End of script output before headers: pytest.py
RichardBlundell
Fri Dec 28, 2018 5:25 pm
I had the same problem (Internal server error), checked /var/log/apache2/error.log and it said "Permission denied - exec of /usr/lib/cgi-bin/pytest.py failed", so I ran a "sudo chmod +x /usr/lib/cgi-bin/pytest.py" to add execute permissions, and the page then worked. Hope this helps someone else!
Schorschi
Wed Feb 13, 2019 9:24 pm
Nice, simple, straight forward. I did not have any issues, worked just fine. Thanks.
martinmmps
Fri May 31, 2019 12:09 pm
What Python Code do I need to get 2 buttons on the Apache Site which run separate functions?
e.g.
def function1():
	pass
def function2():
	pass
Ubuntu users are apt to get this joke
