AliciaCrane
PIR
Sun Jul 24, 2016 11:24 am
Hi, i am new to Pi and i need some help as a beginner.
I am using a RPi3 and with a PIR Sensor.
So I followed the codes in https://www.raspberrypi.org/learning/pa ... worksheet/
from gpiozero import MotionSensor
pir = MotionSensor(4)
while True:
if pir.motion_detected:
print("Motion detected!")
and i have connected the same way as the picture in the link but after running, even though there is no motion, lots of
“Motion detected" is printed and it doesn't stop.
Why is that so?? Is my PIR having problem or the connection for RPi3 is different??
pcmanbob
Re: PIR
Sun Jul 24, 2016 11:47 am
The link you posted is incomplete please try posting it again.
drgeoff
Re: PIR
Sun Jul 24, 2016 12:44 pm
What PIR sensor and how connected to RPi?
Quis custodiet ipsos custodes?
AliciaCrane
Re: PIR
Sun Jul 24, 2016 12:49 pm
pcmanbob wrote:The link you posted is incomplete please try posting it again.
Sorry for the incomplete link.
AliciaCrane
Re: PIR
Sun Jul 24, 2016 12:51 pm
drgeoff wrote:What PIR sensor and how connected to RPi?
Im using the same PIR sensor in this link https://www.raspberrypi.org/learning/pa ... worksheet/
and i connected what is instructed.
However, my sensor does not have the retrigger setting jumper.
B.Goode
Re: PIR
Sun Jul 24, 2016 4:07 pm
There was an almost identical discussion here, from about 2 months ago: viewtopic.php?f=91&t=149724
In that case I think it was concluded that the sensor was faulty.
Return to “Beginners”
