yarmooh wrote:well..this is actually really helpfull!
Indeed I had my own modified files:
-rwxr-xr-x 1 root root 9436 Sep 25 2015 bcm2708-rpi-cm.dtb
-rwxr-xr-x 1 root root 11146 Sep 25 2015 bcm2708-rpi-cm.dts
-rwxr-xr-x 1 root root 1770 Sep 25 2015 dt-blob.bin
-rwxr-xr-x 1 root root 2484 Sep 25 2015 dt-blob.dts
which I used to overwrite default ones. Now when I didn't overwrite them device boots up and is working! hooray!
Other thing would be to find how to change those files to work with new kernel.
dt-blob.[bin|dts] are never shipped via rpi-update or Raspbian images. There is a default baked into start.elf that covers 99.99% of the users. The CM is the exception where there is an expectation that things will change. I don't recall any changes to the CM section of that blob for quite a while.
bcm2708-rpi-cm.dtb is shipped. The source dts file lives in the
kernel tree.
You have a dts file there so you could try a simple diff, although it also then includes various other files.
Try replacing one of those at a time to confirm which one is causing the boot failure.
