solar3000
Multiple SSID/access-points and dhcpcd.conf
Mon Jul 18, 2016 1:33 am
rpi0
so if at home I have SSID: myHome and static IP of 192.168.0.101
and at work I have SSID: myWork and static IP of 10.1.2.3.11
and I want to carry my rpi0 back and forth.
I know in wpa_supplicant.conf I can set two networks.
How is it done with the new dhcpcd.conf method?
Antikythera
DirkS
Re: Multiple SSID/access-points and dhcpcd.conf
Mon Jul 18, 2016 5:34 am
See viewtopic.php?f=66&t=140252 ('arping' method)
solar3000
Sat Jul 23, 2016 3:36 am
I tried that thread.
That doesn't seem to be the answer.
What did I miss?
Antikythera
Sat Jul 23, 2016 5:29 am
You did not miss anything. The thread liked to above is all about setting up static IP addresses which is not what you want to do.
I use my Pi at home and work on the WIFI network at each location. As far as I recall it was just a matter of putting two entries for the two access points in dhcpd.conf
Sadly I'm away from my Pi today so I can't cant and paste that setup as an example for you.
Now, you may also want static IP on the Pi at both home and work. I do that by configuring the WIFI routers to always allocate the same address, static reservation. Not necessarily the same address at both locations mind.
DirkS
Sat Jul 23, 2016 10:43 am
solar3000 wrote:I tried that thread.
What did I miss?
No idea... What did you try?
