Sun Jul 17, 2016 8:07 pm
solo2500 wrote:I'm using a RPi 3b and have a 32GB SD card in it.
Can someone decipher the following memory allocation?
THANKS!
pi@raspberrypi:~ $ free -o -h
total used free shared buffers cached
Mem: 925M 559M 365M 13M 150M 272M
Swap: 99M 0B 99M
AIUI free shows memory allocation,
not available/used uSDHC card space.
The
df command will show you (mounted) filesystem/partition usage on the uSDHC card.
Trev.
Edit: Having now logged in via my P3 I can post an example for a 16Gb card:
pi@raspiP3B16Gb:~ $ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 15185660 3713896 10799288 26% /
devtmpfs 469540 0 469540 0% /dev
tmpfs 473872 0 473872 0% /dev/shm
tmpfs 473872 6424 467448 2% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 473872 0 473872 0% /sys/fs/cgroup
/dev/mmcblk0p1 61384 20984 40400 35% /boot
tmpfs 94776 4 94772 1% /run/user/1000
