What version of Raspbian ? Wheezy or Jessie ?Vairetz wrote:Hi, I install raspbian and I'd like streaming music with bluetooth from my smartphone. I install bluez, blueman (2.0.3) and pulseaudio-module-bluetooth and now on device configuration (in bluman) I see the audio source option but when I try to connect my phone It fails.. the error message is: bluema.bluez.errors.DBusFailedError: No such file or directory. What I was wrong? How can I fix it?
If you had fully updated Jessie, then BlueTooth support is enabled by default, FYI blueman can be buggy:Vairetz wrote:It's Raspbian Jessie 2016
hciconfig -aCode: Select all
systemctl status bluetooth Code: Select all
sudo apt-get install pulseaudio pulseaudio-module-bluetooth
