Vairetz
Analog audio noise
Sat Jul 16, 2016 12:08 pm
Hi, I use my raspberry pi as media center and i connect my aplifier to analog output, but when I'm watching a film or I'm listening to music in background I listen an annoying noise (an hum).. Can I fix it? How can I do?
I made a site with a raspi projects' collection, my idea is sharing my projects with other people.
My web site is https://raspiproject.altervista.org/ I hope you like it and you want work with me
Burngate
Re: Analog audio noise
Sat Jul 16, 2016 4:06 pm
There are a lot of sources of hum, so a definitive diagnosis is difficult.
If you're using a standard wall-wart to power the Pi, there shouldn't be a ground-loop, unless you're also connected to a grounded TV/monitor.
However, if that's the situation, try disconnecting the TV/monitor and see if it improves.
Also, if you're using a four-pole trrs plug in the Pi, are you sure it's wired correctly? (a standard audio-only three-pole plug won't have that problem)
Vairetz
Fri Jul 22, 2016 11:18 am
I use a threepole cable, raspberry now is connected to pc monitor with hdmi and audio jack to amplifier.I try to change the cable but the situation not change
