AbrahamGimar
Vga 666 dual display with HDMI
Mon Jul 11, 2016 11:04 am
Hello, my name is Abraham .
I bought the vga666 adapter with the idea of working with my raspberry using the dual display function .
I have set as indicated in the manual available on github : https://github.com/fenlogic/vga666
But does not the dual display. When configuring the file config.txt . The video output vga but not by the hdmi .
Using the program omxplayer. I can send a video signal by hdmi.
I want to know if it is possible to use dual display with rdesktop . Because in my company we want to change thin client by raspberry.
you know something about it?
thanks so much.
lucass
Re: Vga 666 dual display with HDMI
Tue Aug 16, 2016 1:06 pm
Hey there, any progress? I am trying to do the same thing. An alternative would be going via a DisplayLink USB to DVI adapter...
AbrahamGimar
Wed Aug 17, 2016 6:54 am
Vga666 doesn't work for extended desktop.
I have seen some tutorials using usb vga plugable with raspberry . For example : https://www.youtube.com/watch?v=dTcU5YSq-Ww or https://www.youtube.com/watch?v=XA95jzOyA9w
However, I don't know if it really works well with raspberry . And I don't know what has screen resolution . Also I wonder if you can use remote and extended desktop .
someone has used in raspberry pi ?
thanks !!
Wed Aug 17, 2016 7:48 am
viewtopic.php?f=63&t=150629&p=989609&hi ... 66#p989609
What you (currently) can't do is run desktop apps on both of them. The desktop only runs on one screen. Certain apps (omxplayer, kweb?) can be told to use the second screen.
RPi 4B 4GB (SSD Boot)..
AbrahamGimar
Wed Aug 17, 2016 9:16 am
I know, I want to know if plugable usb vga works with dual display and extended desktop.
thanks !!
john.t
Thu Jan 19, 2017 7:37 pm
how can i do this dual screen using omxplayer?
john.t
Thu Jan 26, 2017 8:49 pm
fruitoftheloom wrote:viewtopic.php?f=63&t=150629&p=989609&hi ... 66#p989609
hello
how can i tell omxplayer to play via hdmi?
thnks john
Thu Jan 26, 2017 9:17 pm
john.t wrote:how can i tell omxplayer to play via hdmi?
You can change which device omxplayer displays on using the --display N option, where N is usually 4 or 5 for the two display interfaces (HDMI/DSI or DPI/VGA)
john.t
Fri Feb 03, 2017 10:16 am
Hello
how can i make omxplayer play on another display via hdmi while my desktop is via vga666?
RaTTuS
Contact: Twitter YouTube
Fri Feb 03, 2017 10:22 am
Covfefe
john.t
Fri Feb 03, 2017 11:07 am
thank you for the reply. but i tried typing omxplayer --display 4 and afterwards also tried 5.but i still plays via vga666. :(
