florian2833z wrote:Hey, can I use my SD card from my raspberry pi 2 model b+ in the raspberry pi 3 or do i have to reinstall the os first. I have Raspbian Wheezy.
The has never been a RPi 2B+
As you are using Raspbian Wheezy put the card in the RPi 2B or whatever you have, then:
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
sudo reboot
rpi-update is generally not recommended to update kernel /firmware unless advised by Developers,.....
.................but as Wheezy is end of life it is the recommended way to undertake so Wheezy can support the Zero & 3B
FYI dist-upgrade is a misnomer it does not update Wheezy to Jessie:
http://linux.die.net/man/8/apt-get
