I recently installed the following fantastic video looper (https://learn.adafruit.com/raspberry-pi ... stallation) directly on my Pi (without using remote access). It works great, However, now, I am unsure how I can shut my Pi down or stop it since I don't have the IP address or have a way to get into the command line. Any ideas? Thanks, Brett
Pressing ctrl-alt-del on a keyboard connected to the Pi should command orderly shutdown and reboot.
The long term solution is to install networking and use ssh from another computer, I guess.
Thanks. The Ctrl-Alt-Del from external keyboard did not work. I am going to try attaching the PI to my laptop via an HDMI cable and see if that can work.
When I unplug it and plug it back in it restarts with the prompt video loop. Not a bad thing since I wanted to build an automatic video looper, but would be great to get "control" back.
