apt-get install mono-develCode: Select all
Setting up libglib2.0-cil (2.12.26-0xamarin1) ...
Illegal instruction
W: removing assembly: failed!
Illegal instruction
Use of uninitialized value $_ in scalar chomp at /usr/share/cli-common/runtimes.d/mono line 275.
Use of uninitialized value $fullname in concatenation (.) or string at /usr/share/cli-common/runtimes.d/mono line 225.
Illegal instruction
E: installing Assembly /usr/share/cli-common/policies.d/libglib2.0-cil/policy.2.6.glib-sharp.dll failed
E: Installation of policy.2.6.glib-sharp with /usr/share/cli-common/runtimes.d/mono failed
dpkg: error processing package libglib2.0-cil (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of libgtk2.0-cil:
libgtk2.0-cil depends on libglib2.0-cil (= 2.12.26-0xamarin1); however:
Package libglib2.0-cil is not configured yet.
dpkg: error processing package libgtk2.0-cil (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libglade2.0-cil:
libglade2.0-cil depends on libglib2.0-cil (>= 2.12.10-1ubuntu1); however:
libglade2.0-cil depends on libgtk2.0-cil (>= 2.12.10-1ubuntu1); however:
Package libgtk2.0-cil is not configured yet.
dpkg: error processing package libglade2.0-cil (--configure):
Setting up libnunit-core-interfaces2.6.3-cil (2.6.3+dfsg-1) ...
* Installing 1 assembly from libnunit-core-interfaces2.6.3-cil into Mono
Illegal instruction
Illegal instruction
E: installing Assembly /usr/lib/cli/nunit.core.interfaces-2.6.3/nunit.core.interfaces.dll failed
E: Installation of libnunit-core-interfaces2.6.3-cil with /usr/share/cli-common/runtimes.d/mono failed
dpkg: error processing package libnunit-core-interfaces2.6.3-cil (--configure):
subprocess installed post-installation script returned error exit status 132
dpkg: dependency problems prevent configuration of libnunit-core2.6.3-cil:
libnunit-core2.6.3-cil depends on libnunit-core-interfaces2.6.3-cil; however:
Package libnunit-core-interfaces2.6.3-cil is not configured yet.
dpkg: error processing package libnunit-core2.6.3-cil (--configure):
dpkg: dependency problems prevent configuration of libnunit-util2.6.3-cil:
libnunit-util2.6.3-cil depends on libnunit-core-interfaces2.6.3-cil; however:
libnunit-util2.6.3-cil depends on libnunit-core2.6.3-cil; however:
Package libnunit-core2.6.3-cil is not configured yet.
dpkg: error processing package libnunit-util2.6.3-cil (--configure):
dpkg: dependency problems prevent configuration of libnunit-console-runner2.6.3-cil:
libnunit-console-runner2.6.3-cil depends on libnunit-core-interfaces2.6.3-cil; however:
libnunit-console-runner2.6.3-cil depends on libnunit-core2.6.3-cil; however:
libnunit-console-runner2.6.3-cil depends on libnunit-util2.6.3-cil; however:
Package libnunit-util2.6.3-cil is not configured yet.
dpkg: error processing package libnunit-console-runner2.6.3-cil (--configure):
Setting up libnunit-framework2.6.3-cil (2.6.3+dfsg-1) ...
* Installing 1 assembly from libnunit-framework2.6.3-cil into Mono
Illegal instruction
Illegal instruction
E: installing Assembly /usr/lib/cli/nunit.framework-2.6.3/nunit.framework.dll failed
E: Installation of libnunit-framework2.6.3-cil with /usr/share/cli-common/runtimes.d/mono failed
dpkg: error processing package libnunit-framework2.6.3-cil (--configure):
dpkg: dependency problems prevent configuration of libnunit-mocks2.6.3-cil:
libnunit-mocks2.6.3-cil depends on libnunit-framework2.6.3-cil; however:
Package libnunit-framework2.6.3-cil is not configured yet.
dpkg: error processing package libnunit-mocks2.6.3-cil (--configure):
dpkg: dependency problems prevent configuration of libnunit-cil-dev:
libnunit-cil-dev depends on libnunit-console-runner2.6.3-cil (= 2.6.3+dfsg-1); however:
Package libnunit-console-runner2.6.3-cil is not configured yet.
libnunit-cil-dev depends on libnunit-core2.6.3-cil (= 2.6.3+dfsg-1); however:
libnunit-cil-dev depends on libnunit-core-interfaces2.6.3-cil (= 2.6.3+dfsg-1); however:
libnunit-cil-dev depends on libnunit-framework2.6.3-cil (= 2.6.3+dfsg-1); however:
libnunit-cil-dev depends on libnunit-mocks2.6.3-cil (= 2.6.3+dfsg-1); however:
Package libnunit-mocks2.6.3-cil is not configured yet.
libnunit-cil-dev depends on libnunit-util2.6.3-cil (= 2.6.3+dfsg-1); however:
dpkg: error processing package libnunit-cil-dev (--configure):
dpkg: dependency problems prevent configuration of libmono-cil-dev:
libmono-cil-dev depends on libnunit-cil-dev (>= 2.4); however:
Package libnunit-cil-dev is not configured yet.
dpkg: error processing package libmono-cil-dev (--configure):
dpkg: dependency problems prevent configuration of libwebkit1.1-cil:
libwebkit1.1-cil depends on libglib2.0-cil (>= 2.12.10); however:
libwebkit1.1-cil depends on libgtk2.0-cil (>= 2.12.10); however:
dpkg: error processing package libwebkit1.1-cil (--configure):
dpkg: dependency problems prevent configuration of mono-devel:
mono-devel depends on libmono-cil-dev (= 4.4.1.0-0xamarin1); however:
Package libmono-cil-dev is not configured yet.
dpkg: error processing package mono-devel (--configure):
dpkg: dependency problems prevent configuration of mono-complete:
mono-complete depends on mono-devel (= 4.4.1.0-0xamarin1); however:
Package mono-devel is not configured yet.
mono-complete depends on libmono-cil-dev (= 4.4.1.0-0xamarin1); however:
dpkg: error processing package mono-complete (--configure):
dpkg: dependency problems prevent configuration of monodoc-browser:
monodoc-browser depends on libglade2.0-cil (>= 2.12.10-1ubuntu1); however:
Package libglade2.0-cil is not configured yet.
monodoc-browser depends on libglib2.0-cil (>= 2.12.10-1ubuntu1); however:
monodoc-browser depends on libgtk2.0-cil (>= 2.12.10-1ubuntu1); however:
monodoc-browser depends on libwebkit1.1-cil (>= 0.3); however:
Package libwebkit1.1-cil is not configured yet.
dpkg: error processing package monodoc-browser (--configure):
libglib2.0-cil
libgtk2.0-cil
libglade2.0-cil
libnunit-cil-dev
libmono-cil-dev
libwebkit1.1-cil
mono-devel
mono-complete
monodoc-browser
E: Sub-process /usr/bin/dpkg returned an error code (1)If anyone has any idea of what is going wrong, or know if what I'm trying to do is even possible, your input would be highly appreciated.
Thanks in advance.
