liudr wrote:Well, it is supposed to be made for beginners to learn computers with. At the very least the program should warn the user that the target is a hard drive or has a very very large volume size for an SD card. It's the programmer's fault to think that everyone thinks like him and guess what, those kids using this program will think that it is the norm that you should feel stupid for not already knowing everything you're supposed to learn. I felt sorry for the OP. I feel the same frustration you have sometimes.
This is utter nonsense. What if you have a large SD card and a similar size HDD?
The program DOES give you a warning that it will erase all data on the destination drive, and asks if you are sure. If you answer yes to that warning then it is YOUR fault, period.
A warning that says you are about to erase all data on something should be ominous enough to get you to double-check your selection, and if you still end up erasing your hard drive, then you should "feel stupid" as you said, because that's a boneheaded mistake. And I know that from experience, I've made a few of them myself, but at least I accept responsibility for my mistakes.
SonOfAMotherlessGoat wrote:It's a very hard lesson to learn, and I've lost data myself, but it's a good time to look at your backup approach as well. If you have data that can (not) be easily replaced, then it really makes sense to backup as much as you can. Things are going to go wrong at times, and it's easy to get lulled into the fact that nothing bad has happened prior so why bother with the expense in time and money for backups. Now you see why.
My best to you in recovering as much of your lost data as possible.
Couldn't have said it better myself. Thanks for that.
