I'm looking for any suggestions on how to repair my SD card or get things to a state where I can retrieve at least some info from my system.
I ran a normal sudo shutdown but when trying to bring my Pi 2 B back online I never get past he startup screens. I get some sort of message about not having enough temp space. Is seems ot free thigns up and keep going but hen stops right after starting lightdm
I'm including some screenshots.
After that last line I just get the small colorful square at the top and nothing seems to go forward from there.
Holding shift at startup take me to recovery mode by my only options there seem to be to overwrite everything. IS there any way I can look in to the filesystem on this car and try to either clean things up or take off some of my config files?
My windows PC only shows the recovery partition and not the others. I might be able to use another pi I have and slide the SD card in to an adapter tha converts to USB and then mount from there. Does nayone have any experiencewith that or any other thoughts/suggestions?
Thanks.
WG
