tony power
raspistill stopped working after kernel update
Wed Jul 06, 2016 4:34 am
Hi
I have rpi 3
I cannot capture images with raspistill but I can save video with raspivid after kernel update.
I did this
sudo apt-get update
sudo apt-get dist-upgrade
reboot
after this step everything works fine but after updating kernel, raspistill stopped working after doing this below.
sudo rpi-update
reboot
here is the error message when I run rapistll.
raspistill: error while loading shared libraries: libbrcmGLESv2.so: cannot open shared object file: No such file or directory
please help me.
the1plummie
Re: raspistill stopped working after kernel update
Wed Jul 06, 2016 5:57 am
I see the same error:
ERROR: Unable to load libopenmaxil.so, reason: libbrcmGLESv2.so: cannot open shared object file: No such file or directory
cjan
Wed Jul 06, 2016 8:54 am
downgrade to --> 01814172b4e6479cc2670fd254dfb738424dbecf
Wed Jul 06, 2016 9:09 am
tony power wrote:Hi
I have rpi 3
I did this
sudo apt-get update
reboot
sudo rpi-update
reboot
please help me.
You should only use rpi-update when advised to do so to fix an issue, it actually installs a Testing Kernel, it is not needed and a standard update / dist-upgrade is sufficient for the majority of users.
As above stated you need to roll back the kernel and do not rpi-update anytime soon..
RPi 4B 4GB (SSD Boot)..
dom
Wed Jul 06, 2016 10:55 am
What does
uname -a
vcgencmd version
ldd `which raspistill`
ls -l /opt/vc/lib
report?
dom
Wed Jul 06, 2016 1:35 pm
Actually I've pushed an update, Can you report it another "rpi-update" fixes it?
tony power
Wed Jul 06, 2016 9:10 pm
dom wrote:Actually I've pushed an update, Can you report it another "rpi-update" fixes it?
thank you, fixed after rpi-update
Bananaman
Fri Jul 08, 2016 2:23 am
Update worked for me too, thanks!
