CedarPrince
How do you connect an AD620 signal amplifier to a load cell?
Tue Jul 05, 2016 6:12 am
Load Cell: http://www.uxcell.com/05kg-weighing-loa ... 26351.html
AD620 Datasheet: http://www.analog.com/en/products/ampli ... t-overview
I think I connect the red and black wires to pins 2 and 3 on the amp respectively; I am unsure what to do with the green and white wires. Can anyone help me here? Thank you very much.
ghp
Re: How do you connect an AD620 signal amplifier to a load c
Thu Jul 07, 2016 5:26 am
these devices form a wheatstone bridge https://en.wikipedia.org/wiki/Wheatstone_bridge.
See the datasheet HX711 ( https://cdn.sparkfun.com/datasheets/Sen ... nglish.pdf ) for a connection sample.
So 2 connections are for the diff amp, one is GND, other is Vcc.
For your amplifier, you need additional ADC to connect this to Raspberry Pi.
Regards,
Gerhard
