Hi Peeps,
I picked up a couple of waterproof DS18B20 temp sensors from ebay and hooked one up last week to a Pi that logs the temperature in 5 minute intervals also logging temps which are above / below a specific threshold.
Since last week the sensor looks to have been working normally in that the logged temperature matches the thermostat on our heater, but yesterday there was a ~2 hour window where the sensor logged abnormally high temperatures (85C) which couldn't have been accurate. I was at home during the period when these temps were logged, the Pi and sensor were on a desk roughly 1m away from me so I can verify that the temp didn't go above 23C and it's not close to any heat source.
After the system logged an 85C reading, it self corrected after 2 seconds logging a temperature in the 'normal' range (22 - 23C) - this happened seemingly at random on 4 separate occasions last night but has not occurred again since.
Wondering if anyone's seen similar behavior with these sensors or can provide feedback on what might be causing it to log such high readings?
