tony power
how do I live stream pi camera
Mon Jul 04, 2016 3:25 pm
Hi
I want to live stream pi camera module using offcial OS Raspian with reasonable delay. I dont want to use OS images for streaming. I want easy and recent method not old and slow one. I searched and found methods by installing much packages I didn't like and got confused.
and I want to be able to view stream on mobile android/ios and vlc application.
my raspberry pi is 3 and offcial operating system installed Rasbian.
RpiName
Re: how do I live stream pi camera
Mon Jul 04, 2016 3:34 pm
tony power wrote:I want to live stream pi camera module using offcial OS Raspian with reasonable delay. I dont want to use OS images for streaming. I want easy and recent method not old and slow one. I searched and found methods by installing much packages I didn't like and got confused.
If you do not want to install any additional software, I do not think that is possible, otherwise install UV4L and choose one of the many ways for streaming mentioned here:
http://www.linux-projects.org/uv4l/tutorials/
Tue Jul 05, 2016 9:10 am
tony power wrote:Hi
You can use a combination of raspivid and gstreamer (note, these are C&P from my notes, so may be out of date)
raspivid -fps 15 -b 400000 -t 0 -n -w 640 -h 480 -o - | tee | gst-launch-1.0 fdsrc ! h264parse ! rtph264pay ! udpsink host=192.168.1.255 port=5000
That will stream out H264 in a RTP stream on port 5000. Another device could connect to that and display it.
On another P (or the same one!) to receive you could do something like this.
gst-launch-1.0 --gst-debug 3 udpsrc port=5000 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! h264parse ! omxh264dec ! "video/x-raw, format=(string)I420" ! eglglessink
mikerr
Tue Jul 05, 2016 9:35 am
tony power wrote:Hi
Well then, I should plug my own android app ;)
viewtopic.php?t=67571
tony power
Thu Jul 07, 2016 1:56 am
jamesh wrote:
tony power wrote:Hi
thank you for the reply
but I want the stream to be viewable using the browser or vlc at least not through a command for my project
tony power
Thu Jul 07, 2016 1:57 am
mikerr wrote:
tony power wrote:Hi
Thank you
but I want to view stream using browser or vlc not through third party application this the requirement of my project
tony power
Sat Jul 09, 2016 4:38 pm
successfully done it using uv4l
Return to “Camera board”
