Reini1000
Raspbain - fast boot into Webbrowser
Fri Jul 01, 2016 11:52 am
How can i boot my Raspberry Pi 3 the fastest way into a Webbrowser ?
I'm using as OS Raspian Jessie. At the moment i'm booting to the text console and a littel script is autostarting the Kweb-Browser.
But how can I speed up the boot process? Is there a possibility to disable loading of drivers which i don't need ( e.g. Bluetooth) and stripping down Raspbian Jessie.
I was trying to build a new kernel but it is to complicated for me. I think a stripped Version of Raspian Jessie would do it, but i could find the right stripped version, e.g. miniban is not suitable for my case.
Thanks in advance !
B.Goode
Re: Raspbain - fast boot into Webbrowser
Fri Jul 01, 2016 11:58 am
Raspbian Jessie Lite and DietPi are two 'start small and add what you need' alternatives that you might want to investigate.
Reini1000
Fri Jul 01, 2016 12:57 pm
B.Goode wrote:Raspbian Jessie Lite and DietPi are two 'start small and add what you need' alternatives that you might want to investigate.
Thanks, i will try Diet Pi and inform about the results. Maybe it's usefull for someone else.
Reini1000
Mon Jul 04, 2016 6:16 am
I have tried Diet Pi, but my main purpose is to boot very quick into a Webrowser, but with Diet Pi my boot time isn't much fast than the normal Raspbian Jessie.
More Ideas ?
kusti8
Mon Jul 04, 2016 6:28 am
Reini1000 wrote:I have tried Diet Pi, but my main purpose is to boot very quick into a Webrowser, but with Diet Pi my boot time isn't much fast than the normal Raspbian Jessie.
More Ideas ?
If you want fast try Tiny Core. But support for software is limited.
Reini1000
Mon Jul 04, 2016 9:03 am
More Ideas ?
Tiny Core is fast your right. Buts its to tiny for me.
Is there a possiblity to speed up the OS Jessie? (e.g. putting drivers which i don't need on blacklist ?)
Mon Jul 04, 2016 9:07 am
Reini1000 wrote:
More Ideas ?
:?: :?: :?: https://webconverger.org/rpi2
RPi 4B 4GB (SSD Boot)..
Reini1000
Mon Jul 04, 2016 9:21 am
fruitoftheloom wrote: :?: :?: :?: https://webconverger.org/rpi2
Thanks but that doesn't fit for me.
Other ideas ? How can i speed up OS Jessie by myself, so i can configure it according to my needs ?
B.Goode
Mon Jul 04, 2016 9:27 am
Maybe you should leave the system running 3600*24*7 to avoid the delay at startup?
Reini1000
Mon Jul 04, 2016 9:40 am
B.Goode wrote:Maybe you should leave the system running 3600*24*7 to avoid the delay at startup?
Yeah you are right thats one possiblity, but i some cases its necessary to restart.
The main Problem is: when my sytem is rebooting, on the screen occurs some boot messages (the auto login to text console process) although i disabled the non-critical bootmessages and the pi-Logo. The bigger problem is that i want to use custom boot screen (i'm using one right now) to prevent that while booting the screen is black or shows bootmessages.
So i want after starting the pi immediately the bootscreen is coming up and lasts until the application is startet. I want to achive that only the bootscreen is visible the whole time (also no black screen while booting) and than immediately the application comes up. If this is not possible, i want at least minimize the time where the screen is black.
Thanks for youre Help!
Mon Jul 04, 2016 9:46 am
http://www.samplerbox.org/article/fastbootrpi
Reini1000
Mon Jul 04, 2016 11:19 am
i have done this:
pi@raspberrypi:~ $ sudo systemd-analyze
Startup finished in 1.936s (kernel) + 33.811s (userspace) = 35.748s
pi@raspberrypi:~ $ sudo systemd-analyze blame
         30.023s hciuart.service
          2.137s ModemManager.service
          1.730s codesyscontrol.service
          1.153s raspi-config.service
          1.151s systemd-logind.service
          1.086s networking.service
          1.060s asplashscreen.service
          1.003s alsa-restore.service
          1.000s dhcpcd.service
           991ms triggerhappy.service
           988ms dphys-swapfile.service
           892ms avahi-daemon.service
           707ms polkitd.service
           609ms keyboard-setup.service
           383ms systemd-fsck-root.service
           354ms console-setup.service
           331ms colord.service
           289ms rsyslog.service
           278ms systemd-tmpfiles-setup-dev.service
           233ms ntp.service
           226ms fake-hwclock.service
           208ms systemd-modules-load.service
           180ms kbd.service
Why does the hciuart.service take so long to start ? Is it possible to delay the start so that first the webbrowser is started for example ?
RaTTuS
Contact: Twitter YouTube
Mon Jul 04, 2016 11:33 am
sudo systemctl disable hciuart
if you don't need bluetooth this is fine
Covfefe
r3d4
Mon Jul 04, 2016 11:34 am
viewtopic.php?t=138223&p=953707
PhilE wrote: If you want Bluetooth to work then don't disable the hciuart service ...
If you don't want Bluetooth then don't edit the service, just disable it.
Reini1000
Mon Jul 04, 2016 11:47 am
RaTTuS wrote:sudo systemctl disable hciuart
Thanks, much better now:
Startup finished in 1.939s (kernel) + 5.903s (userspace) = 7.843s
But one other question, how can i achive that my custom bootscreen is shown while the whole boot process ?
I want to prevent that there are moments where the screen is black during booting ( i disabled the bootmessages and Pi logo).
Mon Jul 04, 2016 12:14 pm
Is a custom bootscreen worth it for something that's going to be displayed for less than ten seconds?
Reini1000
Tue Jul 05, 2016 6:33 am
DougieLawson wrote:Is a custom bootscreen worth it for something that's going to be displayed for less than ten seconds?
Normaly i would say no, but i want to creat a device. If somebody starts the device he should get a consistent display while booting.
Which Services can i also turn off to speed up booting)
I'm booting to the Browser from the Text-Console and i'm using the GPIO´s, but there so many Services which become started. Do I need all off them ?
See attached the analyze graph of my booting process:
Return to “Raspberry Pi OS”
