antonio8909
Problem with video in VLC [solved]
Tue Jun 28, 2016 1:54 pm
Hi there!
I'm new here and this is my first time using Raspberry Pi. I have a Raspberry Pi Model 3 and I can't watch videos on VLC. I use Raspbian and Lubuntu and I can't do it! I can only watch it with GNOME player
Can anyone tell me what I need to do?
Thanks!
PS: Please explain it very clearly. Thanks :|
gkreidl
Re: Problem with video in VLC
Tue Jun 28, 2016 5:41 pm
VLC can display SD video on the RPi 3, if you select SDL for output.
For HD video you need to compile a version supporting hardware acceleration by the GPU:
viewtopic.php?f=66&t=59814
Minimal Kiosk Browser (kweb)
antonio8909
Tue Jun 28, 2016 7:03 pm
gkreidl wrote:VLC can display SD video on the RPi 3, if you select SDL for output.
I run all the steps but it doesn't work. I'm using VLC 2.2.4
HawaiianPi
Tue Jun 28, 2016 11:15 pm
Just use OMXPlayer. It's built-in to Raspbian and supports the Broadcomm GPU for hardware acceleration.
It is a CLI utility that is normally run from a terminal, but you can set it up to play a video when you double-click on it. Right-click on a video and choose open with, then custom command, and fill it out as follows:
Click on image for full size, then use back to return here.
Enter "omxplayer -b" for command line to execute.
Make sure execute in terminal emulator is checked.
Application name doesn't have to be exactly what I put, but you do need something there for a permanent association.
And finally, check the box for set selected application as the default for this file type.
You might have to do this more than once (once for each type of video, mp4, mkv, etc.).
After that, you just double-click on a video and it will play full screen. Use "q" to quit, and check the --help and man pages for more info on OMXPlayer. You can also do the same for audio files, but those can usually be played with other applications as well (audio is much less hardware intensive than video).
There is also an OMXPlayer GUI you can install (a forum search should find you the info on that).
antonio8909
Tue Jun 28, 2016 11:36 pm
HawaiianPi wrote:Just use OMXPlayer. It's built-in to Raspbian and supports the Broadcomm GPU for hardware acceleration.
I tried that but I can't see well the subtitles. They have a "ugly" style. That's why I want to have VLC.
gkreidl
Wed Jun 29, 2016 3:59 am
"It doesn't work" doesn't tell us anything.
I just compiled version 2.2.4 and it does work.
antonio8909
Wed Jun 29, 2016 8:32 am
It doesn't work is It doesn't work.
I can't see the videos yet.
gkreidl
Wed Jun 29, 2016 8:43 am
antonio8909 wrote: It doesn't work is It doesn't work.
Did you select the right video output (Openmax IL)?
Do you try to play videos that are not supported by any HW codec? If they play with omxplayer, they should also work with this VLC version.
antonio8909
Wed Jun 29, 2016 8:47 am
Yes, is in Openmax IL and I tried MKV and MP4 and the same result, a black window.
gkreidl
Wed Jun 29, 2016 8:54 am
antonio8909 wrote:[
How large is your GPU memory?
pi-anazazi
Wed Jun 29, 2016 9:28 am
...recently had a problem with VLC (on opensuse tumbleweed) and black screen for raspi stream, I always had to RESIZE the VLC player window to actually start the video... just saying...
Kind regards
anazazi
gkreidl
Wed Jun 29, 2016 9:59 am
pi-anazazi wrote:...recently had a problem with VLC (on opensuse tumbleweed) and black screen for raspi stream, I always had to RESIZE the VLC player window to actually start the video... just saying...
Openmax IL output in VLC does not output to the window at all; it uses an overlay, just like omxplayer.
Using SDL output (no HW acceleration) does work for SD video on a RPi 3, even for H265 codec.
antonio8909
Fri Jul 01, 2016 6:28 pm
gkreidl wrote:
antonio8909 wrote:[
What's that? Remember that i'm very noob with the Raspberry Pi 3 (this is my first Raspberry Pi)
I don't know if it's related to this
https://www.raspberrypi.org/documentati ... fig-txt.md
gkreidl
Fri Jul 01, 2016 6:39 pm
antonio8909 wrote:
gkreidl wrote:
antonio8909 wrote:[
Yes. You must set
gpu_mem=128
in /boot/config.txt
for full HD video decoding to work-
antonio8909
Sat Jul 02, 2016 12:38 am
gpu_mem was not found on config.txt opened in terminal but I changed it in raspi-config "Advanced options" (Photo attached)
I can't watch any video yet. I can see a big photo of the video but it doesn't continue and I need to press ALT+F2 and put "sudo restart" for take back the control of my Raspberry Pi.
Thanks and sorry for all the problems that I'm causing.
gkreidl
Sat Jul 02, 2016 4:36 am
Did you enable the experimental OpenGL driver? (It cannot work with OpenMax)
Did you remove all packages belonging to VLC before running "sudo make install"?
antonio8909
Sat Jul 02, 2016 8:47 am
gkreidl wrote:Did you enable the experimental OpenGL driver? (It cannot work with OpenMax)
I followed this guide
gkreidl
Sat Jul 02, 2016 9:12 am
antonio8909 wrote:[
I know. I wrote this guide. But something must have gone wrong.
Did you really uninstall all packages related to VLC before running 'sudo make install'?
And you did not answer my question about the OpenGL driver. A simple check: does omxplayer still work?
antonio8909
Sat Jul 02, 2016 9:36 am
gkreidl wrote:
antonio8909 wrote:[
I think that I've uninstalled all VLC packages but I'll try again later.
Omxplayer works perfectly.
antonio8909
Mon Jul 04, 2016 10:08 pm
Hi again,
It doesn't work yet. I don't know what I need to do now.
antonio8909
Thu Aug 04, 2016 4:24 pm
One month has passed and I were trying some things and I can't fix it...
gkreidl
Thu Aug 04, 2016 4:39 pm
Get the output of the error messages (Tools / Messages) and post it here.
antonio8909
Thu Aug 04, 2016 5:18 pm
gkreidl wrote:Get the output of the error messages (Tools / Messages) and post it here.
When I play a video with VLC it freeze and I need to restart using the force (disconnecting the usb)
Will that error messages stay when I restart the board?
gkreidl
Fri Aug 05, 2016 5:37 am
No. And disconnecting power is a bad idea, because it may corrupt the files system on your SD card.
Running nvlc (no interface) from a SSH connection might provide you with a better way of getting error messages. And you might be able to stop execution with CTRL-c and avoid shutting down by disconnecting power.
antonio8909
Fri Aug 05, 2016 11:16 am
I typed nvlc in SSH and this was the result
[email protected]:/media/pi/TOSHIBA EXT/Amnesia $ nvlc
VLC media player 2.2.4 Weatherwax (revision 2.2.3-37-g888b7e89)
[016b9488] core interface error: no suitable interface module
[0161f8f8] core libvlc error: interface "globalhotkeys,none" initialization failed
[016b95f8] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[016b95f8] core interface error: no suitable interface module
[0161f8f8] core libvlc error: interface "dbus,none" initialization failed
I don't know if I need to do more things, again, this is my first Raspberry Pi.
Thanks gkreidl
