Hi, does anyone know how to monitor traffic on the Pi over a remote connection with the Wireshark GUI?
So far I've tried using the native X window server on OSX with
ssh -l pi -X 192.168.1.170 then wireshark, which opens Wireshark in OSX however there are no capture interfaces available and the funcationality isnt all there. I also get the an error in terminal which is a known bug but I'm not sure how it relates to wireshark not working properly.
"** (wireshark:1367): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files"
I also tried ssh -l pi 192.168.1.170 'tshark -f "port !22" -w -' | wireshark -k -i - but no luck, I only get the local interfaces on my Mac.
I'm using Tshark for now but I would prefer the GUI. Thanks for any help.
Re: Wireshark remote monitoring with GUI
Try gksudo wireshark after you ssh in with the -X option.
You can run, but you will only die tired.
Thanks for your reply. I tried what you suggested and it loads wireshark with the correct interfaces but it throws up a few warnings about running wireshark as root, as soon as I close the warnings wireshark quits with an error message.
(wireshark:2004): Gdk-WARNING **: wireshark: Fatal IO error 11 (Resource temporarily unavailable) on X server localhost:10.0.
I followed this http://superuser.com/questions/319865/h ... -on-debian
to run wireshark without root and it opens without the warnings with the correct interfaces however when I click anything on the GUI it closes with the same error.
I'll just stick with Tshark for now and FTP the packet capture if I really need the GUI. Would be nice to have it live.
Forgot to add that I'm running Raspbian and its updated.
When you installed it. Did you do an sudo apt-get install wireshark ?WastedHat wrote:Forgot to add that I'm running Raspbian and its updated.
Did you happen to read through the Wireshark Wiki, especially this part? https://wiki.wireshark.org/CaptureSetup
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
YesRomonga wrote:When you installed it. Did you do an sudo apt-get install wireshark ?WastedHat wrote:Forgot to add that I'm running Raspbian and its updated.
I had a quick read through but I don't have time to explore the links in detail. It runs ok locally on the Pi, it's just being temperamental when I try to get the GUI over SSH.broe23 wrote:Did you happen to read through the Wireshark Wiki, especially this part? https://wiki.wireshark.org/CaptureSetup
I also had issues running the GUI over ssh. gksudo solved that issue for me. I understand you did try it and it failed.WastedHat wrote:I had a quick read through but I don't have time to explore the links in detail. It runs ok locally on the Pi, it's just being temperamental when I try to get the GUI over SSH.broe23 wrote:Did you happen to read through the Wireshark Wiki, especially this part? https://wiki.wireshark.org/CaptureSetup
