juansalvo94
Upgrade raspbian from Pi B+ to Pi 2B+
Fri Jun 24, 2016 2:47 pm
Hello
I got a system working just fine on the RPi 1, all versions (A, B, B+). The system is based in Raspbian but it wasn't designed by me, so i don't specifically what it modifies on the original Raspbian.
The App is simply (i guess), it uses python, html and something called "Supervisord". I simply copy the entire SD Card from one Pi to other in order to "install" the program.
I bouth a RPi2 and i need to make the image booteable. I don't care if i got two separates images, but its better if i only got one that works fine for the two different processors.
Thanks for your time
HawaiianPi
Re: Upgrade raspbian from Pi B+ to Pi 2B+
Sat Jun 25, 2016 3:35 am
Are you saying a copy of your SD card doesn't boot on the Pi2?
Pi1, 2 and 3 all use the same software, but there are some kernel driver/firmware updates for the newer systems. If a straight copy of your card doesn't boot in the Pi2, put the card back into your other system, then run a:
sudo apt-get update && sudo apt-get -y dist-upgrade
After that has finished, shut down and put the card back into the Pi2 and try it.
Sat Jun 25, 2016 8:22 am
juansalvo94 wrote:Hello
If you are using Raspbian Wheezy you will also have to undertake a rpi-update to have the latest kernel.
Though you should be moving to Raspbian Jessie as Wheezy is end of life ;)
