theweissguy
DS18B20 reading high
Thu Jun 23, 2016 6:56 pm
I have a problem with my GPIO reading any of several DSB20 much too high - a constant 85 deg. C. The device isn't even warm to the touch. Any clues?
___________________
theweissguy
DirkS
Re: DS18B20 reading high
Fri Jun 24, 2016 12:36 pm
Show us your setup:
* wiring
* configuration
* software you're using to read the sensor
theweissguy
Fri Jun 24, 2016 2:05 pm
Just checked the specs for the DS18B20 - "The power-on reset value of the temperature register is +85°C". It's clearly not getting the correct 1-wire signal from the PI. Wiring problem? Will check it out later today.
___________________
theweissguy
bensimmo
Fri Jun 24, 2016 3:55 pm
probably, check against this https://learn.adafruit.com/adafruits-ra ... g/hardware
I can tell you if you wire them up back to front they start to reach 85C on their own, they just don't tell you :lol:
theweissguy
Sat Jun 25, 2016 10:13 pm
Problem solved - wrong DS18B20 (PAR version) which only works in parasitic ("true" 1-wire) mode. All works now as it should.
___________________
theweissguy
dentex
Sat Jul 09, 2016 10:31 am
theweissguy wrote:Problem solved - wrong DS18B20 (PAR version) which only works in parasitic ("true" 1-wire) mode. All works now as it should.
Hello.
So are you using the probe in parasitic mode? If yes, could you kindly report some details for its wiring? Thanks!
One of my projects with the Raspberry Pi:
(Raspberry) Pi Aquarium Controller: https://github.com/dentex/piac
theweissguy
Sat Jul 09, 2016 3:13 pm
Sorry, you misunderstood. I was setting up a test for non-parasitic use but had a parasitic only device from a old one-wire system.
___________________
theweissguy
dentex
Sat Jul 09, 2016 3:15 pm
Ok. So it's not a DS18B20 probe, right?
theweissguy
Sat Jul 09, 2016 3:30 pm
Correct - it's a three pin IC from Dallas Maxim.
___________________
theweissguy
dentex
Sat Jul 09, 2016 3:31 pm
Ok thanks.
