alexham
1st Logon fine, than death!
Tue Aug 21, 2012 5:08 pm
Thank you all for advising me on the choice of keyboard and mouse. I bought both from Tesco and loged on for the first time. It all went well, but I must admit that I was disappointed with the apps. The browser does not support Java, so I could not access any of the web based emails, like Windows Live, Yahoo or Gmail. That means that I cannot access many, probably most of my websites and I cannot receive/send emails. Perhaps there are apps that can be downloaded but there is no package manager and I don't know terminal commands to do that.
However, even bigger problem is that I could not log on at all the second time I tried. I set the config to go to the desktop on log on. Perhaps that was a mistake, because I now have a black screen with just HDMI4, which is the connection I use for Raspberry. Nothing else. There are 2 lights on the "motherboard", PWF on continuously and OK flashing.
Any suggestions, anyone?
Thanks,
Alex
mahjongg
Re: 1st Logon fine, than death!
Tue Aug 21, 2012 5:16 pm
During a first time boot the Linux distro makes many modifications to the SD-card, including to files in the FAT partition. If you do not do a clean shutdown, some of these modifications are not finished, this may leave especially the FAT partition in disarray.
Re-flash the sd-card, boot the PI, then once the PI is fully booted up do a clean shutdown with:
sudo shutdown -h now
or do a startx, then do a shutdown from the GUI.
alexham
Wed Aug 22, 2012 2:54 pm
Thank you mahjongg. I have re-flashed the card and shut down in terminal and now it works, but the Logout in LXD sends it into a loop. It goes back into the "BIOS". Logging out in Terminal looks more normal because the monitor actually goes blank. Is that normal?
I am posting this from Midori, which does not have problems with Java.
I tried apt-get install thunderbird in Terminal and got a message that "thunderbird" has no installation candidate, which, I assume, means that it is not available for Raspberry. I could download Synaptic, but there was a warning that it was a large download. Perhaps I should flash a 16GB card instead of 4GB that I am using now.
Is there an email app for Raspberry?
Thank you also for advising me not to attempt to connect PS2 Keyboard with a converter. You saved me a trip and much frustration.
Thanks again,
Alex
Annie
Sun Aug 26, 2012 12:43 pm
alexham wrote:Thank you all for advising me on the choice of keyboard and mouse. I bought both from Tesco and loged on for the first time. It all went well, but I must admit that I was disappointed with the apps. The browser does not support Java, so I could not access any of the web based emails, like Windows Live, Yahoo or Gmail. That means that I cannot access many, probably most of my websites and I cannot receive/send emails. Perhaps there are apps that can be downloaded but there is no package manager and I don't know terminal commands to do that.
I'm using Claws Mail connecting via IMAP and this works really fine for me. I suggest you to try it.
