When I try to enable the experimental OpenGL driver using raspi-config in the terminal, I receive this error message:
"Driver and kernel not present on your system. Please update"
Followed by, "There was an error running option AB GL Driver"
Raspbian is up to date, but I am using Berryboot to dual-boot Raspbian and OpenELEC. I suspect that this is the reason I cannot enable the Open GL driver. (Before using Berryboot, I could enable the driver using raspi-config)
Is there any alternate method to enable the experimental Open GL driver?
I apologize if I've left out any important details, I'll provide any additional information if necessary.
Thanks in advance for your help!
