bongo1024
Windows not rendering properly (black) at 1680x1050
Tue Jun 21, 2016 11:30 am
Does anyone have any hints as to why certain windows and title bars would not render at 1680x1050 and turn our all black? Attached is an example of this. Increasing the video split from 64MB to 128MB on my Pi 3 has no effect. The screen is running a resolution of 1680x1050. This issues only seems to happen in this screen mode, 1920 x 1080 does not exhibit this defect.
Any ideas or thoughts would be greatly appreciated.
Cheers.
Desktop screen capture
hello world :-)
Location: England, in an insecure cloud, ie. The Interwebs
Contact: Website Yahoo Messenger AOL
Re: Windows not rendering properly (black) at 1680x1050
Wed Jun 22, 2016 5:58 am
bongo1024 wrote:Does anyone have any hints as to why certain windows and title bars would not render at 1680x1050 and turn our all black? Attached is an example of this. Increasing the video split from 64MB to 128MB on my Pi 3 has no effect. The screen is running a resolution of 1680x1050. This issues only seems to happen in this screen mode, 1920 x 1080 does not exhibit this defect.
Cheers.
Interesting... If you hadn't said that it doesn't happen at 1920x1080, I'd have immediately assumed it was an issue with your GTK theme. It looks EXACTLY (the Epiphany window anyway) like what I had when I tried to switch the theme to anything that came pre-installed with Raspbian other than Pix. The only theme other than Pix that I've used that doesn't break Epiphany is the Windows 10 theme featured in another one of my posts, and using that theme made the Bookmarks panel in Midori turn black, a lot like the file manager in your screenshot, only the text on the Midori Bookmarks panel didn't turn white.
Also your lxpanel (dock, taskbar, thingy at the top of the screen) looks like it has defaulted to the Fallback theme, which usually only happens when you delete a theme while you're still using it.
I do moral support. Here: https://www.raspberrypi.org/forums/search.php?search_id=egosearch
I know I use too many parentheses. Problem?
Topics I have posted in: http://bit.ly/1NbDdr5
My topics: http://bit.ly/1ObnKqQ
All my posts: http://bit.ly/1OHzje7
autumnwalker
Sun Aug 20, 2017 10:59 pm
I am having the same issue on my Pi - new installation of Stretch and it's showing the same behavior out of the box.
My resolution is 800x480 (touch screen).
Return to “Raspberry Pi OS”
