Info: Pi3 uses a GPIO expander to drive the LEDs which can only be accessed
from the VPU. There is a special driver for this with a separate DT
node, which has the unfortunate consequence of breaking the
act_led_gpio and act_led_activelow dtparams.
This overlay changes the GPIO controller back to the standard one and
restores the dtparams.
Load: dtoverlay=pi3-act-led,<param>=<val>
Params: activelow Set to "on" to invert the sense of the LED
(default "off")
gpio Set which GPIO to use for the activity LED
(in case you want to connect it to an external
device)
REQUIRED
Errr... sorry to be like this, but: Pi B+ came before Pi 2B which came before Pi 3BMKinsman wrote:I see in older documentation that the Status_LED used to be wired to gpio16 but for my Pi which is a model 3 B+ the schematics dont show it being wired to the gpio and gpio16 goes to the header?? is this correct
