AndrewZ
Mouse Cursor Stuck in Lower Left in PyGame Fullscreen
Mon Jun 20, 2016 4:49 am
I've only been working with PyGame and the touchscreen for a couple days, and I've hit something frustrating in my experiments tonight. Previously I wasn't going fullscreen with PyGame, just a nearly fullscreen window. Things worked great, tapping in my zones got the right inputs into code, my program behaved the way I expected, all was well. So I added a keyboard button to quit the program if needed, and bravely went fullscreen, and that's when my problems began...
When in fullscreen mode the first two taps on the screen register correctly, but the third and all subsequent taps register at 799, 479, or the lower right corner of the display.
Also worth noting is that this doesn't happen when the mouse cursor is visible, only when I hide the mouse cursor with
pygame.mouse.set_visible(False)
Have I run into some strange bug with PyGame and the Office Foundation Display, or is something else going on?
AndrewZ
Re: Mouse Cursor Stuck in Lower Left in PyGame Fullscreen
Mon Jun 20, 2016 2:48 pm
For now my work around is setting a very small mouse cursor.
pygame.mouse.set_visible(True)
pygame.mouse.set_cursor((8, 8), (4, 4), (24, 24, 24, 231, 231, 24, 24, 24), (0, 0, 0, 0, 0, 0, 0, 0))
Not ideal, but close enough for now.
texy
Tue Aug 02, 2016 11:56 am
would you be able to post some same code?
I have this problem, and I see that a lot of others have too. When you mention 'fullscreen' or not, are you working within X-Windows?
thanks,
Texy
AndrewZ
Wed Nov 23, 2016 12:17 am
Here's My Code for review. It's been a while since I worked on it, but it runs full screen under Xwindows.
Return to “Official Foundation Display”
