Ivan219
GPIO 27 not working
Sun Jun 19, 2016 1:40 pm
Hello, I have problem GPIO 27 not working - led alltimes in 1. (i try it with gpio 23 -all is working ) Port burned? Raspberry itself works will the port be restored? fuse to fix?
joan
Re: GPIO 27 not working
Sun Jun 19, 2016 1:47 pm
GPIO27 is connected to pin 13 on the expansion header. Is that the GPIO you mean?
Ivan219
Sun Jun 19, 2016 1:48 pm
joan wrote:GPIO27 is connected to pin 13 on the expansion header. Is that the GPIO you mean?
Yes, pin13
joan
Sun Jun 19, 2016 1:50 pm
You could remove everything from the expansion header and try wiringPi's pintest utility.
Ivan219
Sun Jun 19, 2016 2:00 pm
I got:
The main 8 GPIO pins 0: 7: Pin 2 failure - expected 0, got 1
One fault detected.
The 5 SPI pins 10:14: OK
The serial pins 15:16: OK
The I2C pins 8: 9: OK
Faults detected! Output of 'readall':
+-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | IN | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | IN | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 0 | 7 || 8 | 0 | IN | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 0 | IN | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 1 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | IN | 0 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | IN | 0 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | IN | 0 | 23 || 24 | 0 | IN | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 0 | IN | CE1 | 11 | 7 |
| 0 | 30 | SDA.0 | IN | 1 | 27 || 28 | 1 | IN | SCL.0 | 31 | 1 |
| 5 | 21 | GPIO.21 | IN | 1 | 29 || 30 | | | 0v | | |
| 6 | 22 | GPIO.22 | IN | 1 | 31 || 32 | 0 | IN | GPIO.26 | 26 | 12 |
| 13 | 23 | GPIO.23 | IN | 0 | 33 || 34 | | | 0v | | |
| 19 | 24 | GPIO.24 | IN | 0 | 35 || 36 | 0 | IN | GPIO.27 | 27 | 16 |
| 26 | 25 | GPIO.25 | IN | 0 | 37 || 38 | 0 | IN | GPIO.28 | 28 | 20 |
| | | 0v | | | 39 || 40 | 0 | IN | GPIO.29 | 29 | 21 |
It means?
Ivan219
Sun Jun 19, 2016 2:04 pm
I think, that gpio 27 is failure. Can i resolve it?
joan
Sun Jun 19, 2016 3:30 pm
Ivan219 wrote:I think, that gpio 27 is failure. Can i resolve it?
No, once a GPIO is bust it stays bust.
Ivan219
Sun Jun 19, 2016 3:45 pm
It's a pity! :|
Thank you for reply.
