anarchy89
Adding Plan9 Img to Berryboot
Thu Jun 16, 2016 5:41 pm
I'm currently using Berryboot as my bootloader and I have raspbian and kali linux installed.
I am trying to use this guide to add Plan 9 into Berryboot. http://www.howtogeek.com/141325/how-to- ... berryboot/
However, when i key in sudo kpartx -av 9pi.img, i get the following error
add map loo1p1 (254:0): 0 120897 linear /dev/loop1 64
device-mapper: resume ioctl on loop1p2 failed: Invalid argument
create/reload failed on loop1p2
add map loop1p2 (0:0): 0 3661056 linear /dev/loop1 120960
I am new to this platform and would appreciate any help on this. Has anyone tried what I am attempting or know why I am getting this error?
r3d4
Re: Adding Plan9 Img to Berryboot
Thu Jun 16, 2016 8:23 pm
anarchy89
Fri Jun 17, 2016 4:01 am
Yeah I've looked at these, but they don't solve the problem. I can't seem to mount the image.
r3d4
Fri Jun 17, 2016 10:30 am
anarchy89 wrote:Yeah I've looked at these, but they don't solve the problem. I can't seem to mount the image.
How did they not solve the problem ?... && what else did you try ??
:? did any other links you found not 'solve the problem' :?:
Return to “Plan 9”
